Results 1 to 14 of 14
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    so, is this a bad coil pack?
    It idles and revs (in neutral) fine but when I put a load on it, it starts to studddddder.
    The MIL came on and stayed on.
    Thanks,
    Bill
    Deactivated Three Rings
    Apr 11 2008
    Re: so, is this a bad coil pack?
    I always thought a bad CP caused problems during idle, too. That's why people play the CP game when trying to find which one to replace..
    Houston
    Quote Originally Posted by swrt83 View Post
    That’s what I thought.....I'm in Houston and gas was hard to come by right after Ike and I had to put in regular (87) (after waiting in line for an hour) because that’s all they had.
    This just happened about 2 hours ago, so I put in 2 bottles of octane booster (glad I have a case in the garage) and filled up with 93.
    By-the-way....I still don't have electricity 10 days later!!!!
    Apr 11 2008
    Damn! Sorry to hear that dude.. as for the ride, i'd just drive her nice and easy on 87AKI
    EDIT: just noticed you filled with 93. Hopefully it was just from the low grade gasoline and nothing due to the weather!
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    Quote Originally Posted by 80CID View Post
    i heard gas is around $6 bucks....true?
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    depends on what kind of studder, theres the very Obvious 'I'm running on 3 pistons studder' and the less than obvious 'i'm hitting misfire counters in VAG and it looks like probably piston # _____ has a coilpack that cant handle a higher KV range' studder , find out which piston is misfiring and replace coilpack FTW woo
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Houston
    Quote Originally Posted by 04TurboB6 View Post
    Not true.....it was a little bit higher....but it was really hard to find a station that had power or a generator to pump the fuel and then some of those only took cash.
    I paid $3.93/gal
    I have a generator and a windershaker (window mounted a/c) just for this purpose so we can at least sleep in a cool bed room.
    You don’t realize just how much you depend on electricity until you don’t have it for 10 days. (It will be 10 days tonight at 11:00).
    This week end we had to use a laundry mat……you know how long it has been since we’ve used a laundry mat? And it was full you had to wait for a washer and they had 30 washers and only 20 dryers….yes I counted them.
    Houston
    Quote Originally Posted by treemolecule View Post
    can I take it to Auto Zone and have them scan it.
    What is the name of the scan tool that everyone here uses? I guess its time to get one.
    Jan 13 2008
    Charlotte, NC
    just an obdII scanner, or take it to a german tuner and have it VAG scanned, most people cant keep up with the $1000 a freakin month just to use VAG so just get yourself a nice OBDII scanner
    GReddy Turbo Timer
    Forge TIP (RED)
    Apr 11 2008
    1000 a month? what? go to ross-tech's website and get yourself one. i paid roughly 250 on an older one (non-CAN) they're a worthwhile investment if you work on your own car. otherwise yeah, autozone can scan it with an OBDII scanner and give you codes (most of the time for free) and then you just need to look up the codes (VAG-COM gives you info on these codes)
    Houston
    So is this all I would need?
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    Apr 11 2008
    yeup! just note that they won't work with the newer model so if you ever plan on updating to a b8 soon i would get the CAN one
    Houston
    yeah this one is paid for (2004) and I like it that way.
    Houston
    ok I'm home but still no elec.
    so I'm using my phone for this reply.
    went to Auto zone and its cyl. 2 missfire.
    What coil's should I get?
    Thanks
    Bill
