Thread: Slow take off
    Registered Member One Ring Two Face's Avatar
    Apr 16 2007
    1998 A6 , 1993 ACURA LEGEND L
    Washington DC
    Slow take off
    is there anything, short of engine swap , that can be done to improve a 98 C5's time off the line????????? don't want to chip her yet. My first mod has been 10000k HID conversion kit and i'm llook for a set of a8 RIMS.
    http://www.cardomain.com/ride/2594856
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Slow take off
    k&n filter, that's about it.
    otherwise just make sure you keep fresh oil & plugs, and that you have no vac leaks.
    nothing is going to make you faster than that 10,000k SuPErHID!!
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Apr 16 2007
    Washington DC
    Re: Slow take off
    was thinking about a short ram intake - eith injen or k&n . would that work or would the stock air bok with the k&n filter be better?
    Feb 13 2008
    Re: Slow take off
    if you want to be quicker off the line, don't add the unsprung weight bling you're showing on the cardomain page.
    Nov 20 2005
    Re: Slow take off
    "short ram" or open element intakes lose points becuase they just suck the hot air in from your engine so you will end up losing power in a long run...
    for your next question use this link...
    http://www.audizine.com/forum/search.php
    is it 4:20 yet?
