Results 1 to 7 of 7
    Apr 01 2005
    one wagon one truck
    Michigan
    APR Throttle body hose
    Do you own one?
    Do you like it? Is it worth 159.00? Do you use something else?
    Thanks just trying to get some ideas on if I should order it or if I should start looking at something else.
    TIA
    Feb 17 2005
    Sarasota, FL
    Re: APR Throttle body hose
    I had one way back when with a K04. Its as good as a silicone pipe can be
    Apr 01 2005
    one wagon one truck
    Michigan
    Does anyone else make them?
    Feb 17 2005
    Sarasota, FL
    Forge possibly
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Your stock one can hold up to a lot of pressure. I personally think it's a waste of money, now the TIP is a great investment. The stock TIP collapses under pressure and it get's very flimsey and rips easily. I would invest in a TIP if you don't have one already.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by audiluxary View Post
    how much pressure?
    say, GT28rs unitronic pressure?
    Just wondering since the FMIC I bought only had piping to connect to the throttle hose.
    Apr 01 2005
    one wagon one truck
    Michigan
    okay, I am getting a noise around 10 on the outside of boost so I was wondering if maybe it was that. Maybe ill try a TIP first and see what happens.
