Results 1 to 11 of 11
    Veteran Member Three Rings Clown4's Avatar
    Aug 29 2008
    '08 Quartz Gray S-Line B7 2.0T
    Rainbows and Unicorns
    mild trembling/shaking from the steering wheel?
    In this afternoon, I was driving on a highway, took my 2.0T to around 110-120km/h. It was actually a cold day, but no rains on the pavement.
    I didn't feel the steering wheel trembling on the way to another city. But on the return trip(I used the same highway), around the same speed, I felt the steering wheel trembling a bit. And when I released my both hands to observe this mild movement, I could see the steering wheel was kinda shaking in a mild rapid rhythm.
    Could this be possibly caused by the profile of the pavement(not very smooth, or because one side of the pavement was higher than the other side)??
    Or maybe it was because of the fact that I put it in 6th, and was running with low rpm's?
    I'll give it another run tomorrow. This was just the feedback I got from the car today.
    If any of you had encountered a similar situation, please share it with me : )
    many thanks in advance!
    2008 B7 A4 Quartz Gray 2.0T Quattro 6-spd MT.
    Full S-Line | Special Edition | Technology Package | HomeLink
    ____The Last of B7._
    Aug 08 2008
    2017 Q5
    Houston, TX
    Re: mild trembling/shaking from the steering wheel?
    i have a slight vibration too. its off and on. i attribute that to the rpms though. could be wrong. the only time i had those vibrations in my old car (civic) was when the breaks were going bad. =T
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    Might have thrown a weight at some point in the trip?
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Aug 29 2008
    Agorich:
    It didn't happen while breaking. That'd only happen to cars that have worn out brakes I suppose.
    Quote Originally Posted by TheHeggi View Post
    hmmm, by "thrown a weight at some point", you mean "pedal to the floor" ?? if that's what you're suggesting, then it could be the reason..?
    thanks for the inputs guys!
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    he means you could have lost a stick on wheel weight causing imbalance in a wheel...or I was going to suggest you may have a slight bend in a wheel.
    Mar 14 2005
    stl mo
    OP: is the mild shaking constant at any speed, or it only happens above certain speed?
    2003 Platinum Grey MKIV Jetta 1.8T Tip[sold]
    2002 Dolphin Grey B6 A4 1.8T 5spd Quattro[sold]
    2005.5 Quartz Grey B7 A4 2.0T 6spd Quattro[sold]
    2011 Brilliant Black 8p A3 S-Tronic Quattro
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    Could be they've repaved only one side of the highway. Did you feel anything through the pedals?
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i too have been experiencing this for months. appears to only happen between 55-65 mph. most notably at 60 mph. then tappering off until about 80 where things seem smooth again.
    i have tried wheel balancing to no avail. very annoying. wonder if a wheel is out of round slightly...
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Aug 29 2008
    to Aspw:
    It happened only when I was driving around 110-120km/h.
    I don't think there's anything wrong with the wheels, haven't drove it over potholes or bump the curve or anything like that.
    That could've been a reason though! thanks man!
    Quote Originally Posted by eMacPaul View Post
    nope, not even the slightest shake from them pedals.
    In regard to the pavement, the inner lanes are usually a bit higher than the outter, so when it rains, it could be drained easier.
    So, I was guessing that could've been a part of this trembling.
    I'm gonna take it for another highway run later today.
    again, many thanks for the thought!
    Aug 29 2008
    Quote Originally Posted by toothysaw2 View Post
    yeh, I guess i was running it around 63 mph? somewhere along the line.
    It was kinda annoying to me..especially when you've just bought it for almost a week only?
    The handling's superb in all ways to me thus far, aside from this.
    Nov 12 2007
    Grand Junction, CO
    sounds to me like an out of balance tire. Most likely in the front. You may want to go to a shop that can balance tires and have them check it out.
