Results 1 to 22 of 22
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    Talking Installed Fogs on DTM, and JHM Short Throw
    Just finished installing the Hella Xenon fogs and JHM short throw shifter in the beast! All in all, a 12 hour job with 2 people, but well worth it in the end! BTW, for anyone thinking about these installs, the JHM is easy, but be sure you're careful about your adjustments on the shifter, it's really easy to throw the gears off (first time I tried it I had no reverse, haha). The fog lights...well...make sure you know what you're doing, because it's a pain in the arse. Here's just a few pics of the fun...
    Stock Shifter:
    JHM Shifter:
    Breakin it down!
    Ballast
    Scariest part of the night
    BBS Pizza is the best!
    DONE!!
    I WILL EAT YOU!!
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    Dec 05 2006
    So. Cal.
    Re: Installed Fogs on DTM, and JHM Short Throw
    Nice work. Do you have an up-close shot of the fogs and the surround (lights off)?
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    I dunno how I feel about the foglights when off. Just keep'em on all the time and you're set! ahaha
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Impressive. But why not just have put the S6 LED's or something along those lines? More importantly though, you're the first person who hasnt scared me with the JHM install. Was finding the gear after installing really that straightforward for you?
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    May 26 2008
    Moraga, CA
    Quote Originally Posted by Cargo8
    The fogs were actually on in that pic, but the angle and gasrage lighting were weird and made it seem like they weren't. I definitely agree they look better on though and have been driving around with them on, haha.
    Quote Originally Posted by whartung View Post
    I live in the Bay Area, so it get's really foggy here. I definitely looked into the S6 LEDs because I think they look great, but they are considered by Audi to be "running lights" and don't actually throw that much light out in front. Thus, wouldn't do me much good for the fog unfortunately. As far as the JHM, I really didn't have much problem with it at all. In the adjustment phase, you just have to go slow and tweak it little by little until you find that spot where all the gears are smooth. At first I had no reverese, so I moved the neutral more to the right, tried again and it was good, but first and second were notchy, so moved it back to the left a bit and bingo. It just takes some patience to find it, but it's really no problem at all.
    Quote Originally Posted by RAudi Driver
    I think this is what you were lookin for ya?
    Four Rings Racing
    '07 S4 DTM
    Dec 05 2006
    So. Cal.
    once you have the JHM centered, there is only one bolt to mess with. go through your gears, then loosen the bolt and adjust it one way. It's either going to get better or worse. If it gets worse, adjust it the other way. Once you know which way does what , it really easy.
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    looks good. the dtm looks gross w/ no fogs
    May 26 2008
    Moraga, CA
    Ya, and it's a REALLY small adjustment, you don't want to go very far in any direction. 1-3 degrees of change make a big difference! JHM recommends 3 degrees right, 7 down and I'm probably running around 3 right, 5 down
    Four Rings Racing
    '07 S4 DTM
    Established Member Two Rings cucubee5's Avatar
    Oct 30 2006
    B7 A4
    New York, New York
    Quote Originally Posted by S4DTM View Post
    This is the one thing that has held me back from getting the DTM front...until now.
    Nice job! More daytime pictures would be great.
    Feb 01 2007
    Sorry to thread jack. Thanks for the info. Good job with that diy
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Which short shifter did you get - I think there are three choices. How do you like it vs. stock?
    FS: Audi TT 225Q Roadster
    May 26 2008
    Moraga, CA
    Quote Originally Posted by EYE4SPEED View Post
    I went with the stock height and just normal short throw, rather than the "Extra" short throw. It's A LOT better than stock, faster and more solid, and I'm glad I went with the stock height because it's not more to get used to.
    Four Rings Racing
    '07 S4 DTM
    Dec 05 2006
    So. Cal.
    Those fogs look great. Regular length is better than a short length as you don't have to reach as far to shift gears.
    May 26 2008
    Moraga, CA
    Quote Originally Posted by cucubee5 View Post
    I should have some daytime pic on thursday (gotta get the beast washed first), and I'm goin to take some night pics on saturday...I'll post em when I'm done
    Four Rings Racing
    '07 S4 DTM
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    Could you get a closeup pic of a foglight/trimmed grille?
    How did you actually mount the fogs? Pics?
    Wired to headlight switch so it works like every other S4? Or did you install your own switch?
    I've wanted to do this for a while, but with OEM fogs and modified grilles. It just seems like too much work with too little time to work on it.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    May 26 2008
    Moraga, CA
    Quote Originally Posted by VR2V8 View Post
    Here's the link to all of the photos I took. I think there's a few in there of what you're looking for. I attached them to a small plastic ledge just above the grilles. I also used a metal brace piece to support the light a bit more, and it made it very sturdy. Take a look at the pics as there are some of these steps. The lights are wired in to the headlight wire, so they are on when the headlights are (just like stock). Tried to get them to stand alone with the reverse fog switch, but it was 12:30am and I just wanted to be done, haha. Anyways, take a look at the pics and let me know what you think. Like I said, I'll also have more pics on thrusday
    http://www.flickr.com/photos/3075709...7607462481437/
    Four Rings Racing
    '07 S4 DTM
    Veteran Member Three Rings frrg's Avatar
    Aug 11 2008
    2001 Komotik
    Gibbs Fiord
    Looking forward to bagels Friday morning.
    DUH! an Audi
    los angeles, CA
    FRRG! haha FTW
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Personally I think it looked better without the fogs.
    The clipped fog grilles look cheap.
    May 26 2008
    Moraga, CA
    Quote Originally Posted by MOFSTEEL View Post
    Everyone is entitled to their own opinion, sorry you don't like it but not much else to deal with, so had to made the best of it.
    Four Rings Racing
    '07 S4 DTM
    May 26 2008
    Moraga, CA
    Quote Originally Posted by Quattro View Post
    FRRG! haha FTW
    Best comment that could have been posted! Although I'd go with FRRG FTMFW personally, haha
    Four Rings Racing
    '07 S4 DTM
    May 26 2008
    Moraga, CA
    I know a few of you wanted some daytime pics, so I snapped a few today. Not the best pics, but all I had time for this afternoon. You get the idea though. Should be takin some good shots over the weekend though, but here you go so you can see the look in the daylight. Enjoy
    Four Rings Racing
    '07 S4 DTM
