Results 1 to 6 of 6
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Alright, check engine light help?
    check engine light came on and the code reads for lean mixture.....what does it sound like to you guys???
    vacuum leak?
    Feb 27 2005
    North Wales, PA
    Re: Alright, check engine light help?
    maf
    Dec 05 2007
    What are your codes? Mods?
    Sep 17 2005
    Dublin
    You'd have to have a giant gaping vac leak to run lean to the point of triggering a fault. Your engine would run like ass if that was the case. Every time I've seen a lean code that wasn't on a highly modified a4 it was a bad maf. Do you have access to vag com?
    2000 A4 1.8T
    1997 A4 1.8TQM
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I had a small vacuum line pop off from the front of the manifold and had a Lean code and limp mode. It don't take much of a leak.
    Still...MAF
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Aug 25 2008
    rhode island
    yah sounds like the maf, my buddy was messin round with it he other day.
    thanks guys.
