Results 1 to 15 of 15
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Brake Upgrade Q:
    Hey everyone... I was wondering if there is a rear brake upgrade for our B6's.. I know for the front the cheapest way to go is S4 B5 brakes... im gonna get that shortly... But what about the rear?.. i know rear brakes arent segnificant, but just for looks i'd like to go bigger.... What are the options, if anyt?..
    thanks
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Re: - Brake Upgrade Q:
    I did B7A4 Front/Rear Conversion.
    B7A4 Fronts are MONSTERS compared to B6A4 Fronts.
    B7A4 Rears are about the same size as B6A4 Fronts
    B6 Front - Top Left
    B7 Front - Top Right
    B7 Rear - Bottom Right
    Dirty Ass Piece of wood - Top Top Right
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    May 26 2005
    CLS63tt
    Boston
    tormoza dlya trusov
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Quote Originally Posted by 617 Bones View Post
    B6 Front - Top Left
    The B7 and B6 fronts are almost identical (caliper size wise). The B6's pictured just don't have the carrier on them.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Jul 11 2008
    Illinois
    S4 Rear Conversion from ECS is as big as your gonna get for rears
    Anthony
    Established Member Two Rings samaritano's Avatar
    Jun 05 2007
    Miami, FL
    B6 Front - Top Left
    So, would the factory rear caliper on a B6 with 245X10mm work with the B7 caliper carriers and the 288X12mm rotors?
    Edgar
    Apr 12 2007
    Milwaukee
    it won't work
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by pizdetsauduxa View Post
    tormoza dlya trusov
    Ha LOL
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Buncha motorcycles
    Memphis, TN
    i like big rears
    APR Stage 2/AWE Intake
    Feb 17 2005
    Sarasota, FL
    Stasis/Alcon, Brembo, and Stoptech only recommend a rear upgrade with AT MINIMUM 355's up front inorder to keep OEM bias. If using an OEM upgrade up front, I would upgrade to a better (same size) rotor in the rear with new pads, lines, and fluid. This is of course for the function over form idea!
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I have the ECS S4 rear brake upgrade kit along with my Stoptech 332 BBK up front. I also have stainless steel brake lines, Ferodo DS2500 front pads, Carbotech Bobbat rear pads, and Motul RBF600 brake fluid. I've had this setup now for over a year (and about 30-35k miles). I absolutely love this setup! I've done several track sessions with zero brake fade. The back end does not brake out from me. When I hit the brakes, it's like a giant hand pressing down on the entire car.
    USP CLUB MEMBER #34
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by A4ringedONE8T View Post
    does that mean if i get brakes from a b6 s4 on all 4 corners that the bias won't be correct?
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by NyteEscape View Post
    You will be fine however it wont have the same bias as an S4. Different master cylinder and proportioning valves
    Aug 10 2007
    Toronto, Ontario
    thanks guys... :) very helpful
    russkie, zaparili "haha"!... lol
    Jun 05 2007
    Miami, FL
    Re: Brake Upgrade Q:
    I just bought a B6 S4 front set of brakes and was planning on going 3.0 on the back. Is that ok to do?
    Edgar
