Results 1 to 4 of 4
    Veteran Member Three Rings freeflow's Avatar
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    Power question with sport mode
    This may be a noob question, but here it goes.
    Since our peak torque/hp is between 3500 to 5300 rpm with APR 93, under straight hard acceleration doesn't it make more sense to not use Sport mode with the auto tranny since sport mode keeps the RPMS higher in the power band than the regular drive mode?
    Keep in mind im talking about the CVT 7-speed multitronic... yes i know... totally gay and wish i got quattro.
    And also keep in mind im talking about flooring it in a straight line for max acceleration, not response time from the tranny which Sport mode obviously gives you.
    Data: Dyno results
    APR 93-octane
    DYNO AWHP 196 @ 5000 RPM
    DYNO TQ 223 lb-ft @ 3650 RPM
    PEAK GAIN, HP* 60 hp @ 3900 RPM
    PEAK GAIN, TQ* 83 lb-ft @ 3200 RPM
    0-60 MPH 6.8 sec.
    1/4 MILE 15.2 sec. @ 89 MPH
    2007 A4 2.0T - Brilliant Black on Black - Premium - 5% tint - 7 spd multitronic - APR 93/Stock - RS4 Sway - FLY's LEDs - CC'd - LED License Plate - Interior xenonmatch - Hoen Fogs - Debadged - VAGed
    Wish list: Stassis Coils, Carbonio CAI, HFC, 19" R8s, Ecode CF Hood, CF Rear Wing, ECS Blackout RS4 grille, S4 blades,
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: Power question with sport mode
    I usually have it the Tip mode and shift at 5500 rmp so boost does not go lower than 15 psi and for it to spike again at almost 20 psi. I usually don't like using it on sport since ratios change and it shifts where there is no power. I only use S when I want to chirp the tires on the move.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    I would like to time D vs tip.
    -EI AL CAI.
    -Driver Mod.
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    Quote Originally Posted by HID View Post
    That would be an interesting comparison. Let me kno if u do that.
    Shifting in tip at about 5500 sounds like you'd get the most consistent boost, although i don't have a boost gauge so i cant verify that. I've noticed on the highway that i get more pull in drive than sport tho hands down, so that's where my initial question came from.
