Results 1 to 3 of 3
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    Arrow Mercedes to Audi wheel adapters
    can someone refer me to a website where I can pick these up? I just need to convert benz's 66mm hub center to Audi's 57mm. Thanks guys!
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Re: Mercedes to Audi wheel adapters
    You don't need wheel adaptors just hubcentric rings. Depending on the wheel, Tirerack may be able to help. Tirerack helped me when I bought some BBS CH's that were used on a Benz and had hub rings in the Benz size.
    Note, if you're dealing with BBS wheels and they have hub rings now, look really close at the hub ring when removing it as there will be a small opening/slot that you need to use a flathead screwdriver (or something similar) to work out the ring that holds the entire thing in place.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    If its a brand we sell, we can get the rings. List of brands is here:
    http://www.tirerack.com/wheels/wheelbrands.jsp
