Alright, so I removed my transmission today but as I was lowering it was caught on some wiring and tubing, so I got most of it out of the way and continued. Through out the lowering, a very small amount of near clear thick liquid dripped out between the bell housing and transmission, whether this is normal I do not know. When I got everything out of the way, I noticed a small spot where something had leaked (designated by the red arrow). It seemed as if it had come out of the hydraulic line ( green ) or the tube ( pink, has liquid in it ). It would be a real pain to have to take my transmission out to replace these later if they were leaking. Does anyone know what those tubes are or what was leaking? It was a very small amount and is no longer leaking. Just trying to be on the safe side. My best guess is it was pulling on it when it was lowering and leaked a little out and then closed back up. I do find it weird that there is a nut missing on the bolt that holds the hydraulic line though.
Also, anything else I should do while I have the whole thing apart?
ALSO, the bolts the connect the cat to the middle exhaust all snapped and half of the bolts are now stuck in the cat side. They wont come out, even with a butane torch. Do I really have to get a settling torch to remove these?
If you couldn't figure it out, this pictures is right above the clutch/flywheel. You can see the bare plate in picture 1. Pictures 2 and 3 proceed to a more vertical view.
