    May 16 2008
    WA
    Any Tips For the Process of Replacing the Knock Sensor?
    So with the help of some fellow AZ'ers i was able to narrow down that my knock sensor on the rear of the block has to be replaced/retorqed. I tried searching both the forums and google but couldn't find anything like a DIY/Walkthrough/etc on how to get at this, and it looks like a pain, so....
    I was wondering any of the following:
    1.Who here has had to replace this sensor? and did you do it yourself?
    2.What needs to be removed to gain enough access to it to do the job?
    3.Any tips or tricks to help?
    4.Has anyone been more successful than i was at finding a guide that would help in this job go a bit more smoothly? (DIY/Walkthrough/Guide...)
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Any Tips For the Process of Replacing the Knock Sensor?
    Long extension, universal joint and small hands. Remove anything that's in your way. There are zip ties that are hard to reach but they are reusable kinds so don't cut them.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    97 A4 2.0TQM
    Rochester, NY
    I'd suggest pulling the intake manifold, it's not hard and will make the job 5000x easier. You can clean up down in there too (and check the condition of your PCV parts) with it off.
    May 16 2008
    WA
    Quote Originally Posted by Nebone View Post
    so were you finally able to replace yours? about how long did it take, and how many bloody knuckles lol
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I replaced my front one closer to cyl 1 and took like half hour. The one you need to replace, well, I can't even see it. I'd also recommend pulling the intake manifold.
