Page 1 of 4 123 ... LastLast
Results 1 to 40 of 145
Thread: fastest ko3?
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    fastest ko3?
    just wondering if anybody has gone balls out with the ko3 before going bt... I was thinking 20psi+, meth/h20 with upped timing, 2step, n20, cams, fmic, etc? just wondering if anyone has broke 13's i guess?
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Re: fastest ko3?
    tallest midget?.........anyone?
    "Obsessed" is a word that the lazy use to describe the committed.
    Apr 22 2007
    Riverbank, Ca
    Re: fastest ko3?
    At the point of getting a FMIC, anything after that people generally go bigger turbo..
    I did 6.5 0-60 on my K03...
    GIAC
    FMIC
    Airbox mod w/ KNN
    Borla exhaust w/ cutout
    Forged DV
    I was showing 170AWHP on my Gtech.
    Feb 27 2005
    North Wales, PA
    Re: fastest ko3?
    mike hoods was the fastest and probably still is.
    Apr 22 2007
    Riverbank, Ca
    Re: fastest ko3?
    What did he run on a K03? Link?
    Jan 14 2008
    2001 A4 1.8TQM
    Broomall, PA
    Re: fastest ko3?
    on my 01 i'm running an aeb head and manifold, 034 exhaust manifold, phenolic spacer, full turboback with testpipe, racetech fmic, samco tip, unitronic custom file, yada, yada, yada...basically everything possible bolt on wise to the stock K03S and then some. I'll post numbers as soon as i get to the track and dyno.
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    i know its not the easiest route just curious to see what the little guy has been able to do...
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: fastest ko3?
    little guy is onyl capable of mid 14s if i recall correctly
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    BS mine ran 14.8@92 with giac ecu, 3"tp, modded airbox and borla.... Im sure 13's are possible
    Hell just a mbc, 100octane tune, and 2step with a decent clutch i think i could have got 14.5!
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: fastest ko3?
    Full 2.5in straight pipe exhaust + custom (as in ME only tuning it) tune + 21psi + monster k03 + FMIC + shit clutch
    I was hanging with a 14.4sec Camry. Dead even from 25 to 120.
    ÖMGHI2Ü
    Photography
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    what kinda camry runs 14.4 impressive! And whats a monster ko3? ko3s im guessin
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: fastest ko3?
    Ive heard of a k03s running high 13's...
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    f it, im going for 13.9 if the turbo doesnt hold together than i will upgrade to my Gt28... Im curious now!
    Veteran Member Two Rings
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Re: fastest ko3?
    You wanna go faster for cheap? Loose weight, take off bolt ons.
    Current:
    2001 Audi A4 Avant, Stage 3 (17 years, 120K)
    Sold:
    1999 Audi A6 Avant, Worn (3 years, 134K)
    1996 Audi A6 Avant (5 years, 155K)
    *(Owned, Odometer)
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: fastest ko3?
    Quote Originally Posted by big_greasy_taco View Post
    Ive heard of a k04 running high 13's...
    fixed
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 27 2005
    North Wales, PA
    Re: fastest ko3?
    strip it downnnnnn. i'm talking everything....its free...and sell off the parts for more go fast parts
    Jun 01 2008
    Apopka, FL
    Re: fastest ko3?
    Quote Originally Posted by andyrew View Post
    GIAC
    FMIC
    Airbox mod w/ KNN
    Forged DV
    without a FMIC, I made 170AWHP and 200FT/lb tq on the dyno with on giac software with milltek exhaust and a test pipe, stock everything else except for a snub and 710N, I think with the SMIC I'd spike to 20PSI or so, post FMIC is more like 17-18psi and holds at 15-16..
    now that I have the FMIC, a clutch that dosen't slip and track density motor/tranny mounts, I think the dynolicious software puts me at 6.3 0-60 at 180whp the best pull I had.
    cams would only hurt performance on a k03. overlap on such a low power setup is never a good thing. cams only really start making a difference past 30 series garret turbos. Also, 20+PSI is out of the effeciency range of the k03 as well. 12-15PSI is the best spot.. anything past that is best seen as a spike, but will die off anyway higher than 4.5-5K
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: fastest ko3?
    Quote Originally Posted by Poopie View Post
    I think it would take more than that.
    Ha, Not in a B5 Chassis. Maybe a MK4.
    14.63 @ 92.8 MPH. I know I could do better in the 60', but this is a full weight (3383lbs) car.
    IIRC Mike ran a 14.3, but PLEASE don't quote me on that.
    Apr 28 2008
    Houston, TX
    Re: fastest ko3?
    Quote Originally Posted by djwimbo View Post
    Completely gutted b5 with a ko3s ill bet would be damn close
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: fastest ko3?
    I ran a 14.53 at 94mph with ko3s @22psi, ported o2, test pipe, speed tuning, forge 004, short shifter. about 100lbs taken out( jack, spare, toolkit, carpeting, trash etc. With nitrous Im sure someone could break 13's. Theres a youtube video of some guy with a stock ko3 and nitrous with 298whp. Im really considering getting a 50 shot, when the funds are adequate.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    Re: fastest ko3?
    what other easy to do weight reduction mods are there with out paying alot for cf,
    what else is there besides jack, spare, toolkit, carpeting, trash, rear seats..
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Jun 01 2008
    Apopka, FL
    Re: fastest ko3?
    Quote Originally Posted by TheWrightAudi. View Post
    rear seats, carpeting, spare? I wouldn't want to go that far, that's more a ricer thing imo. it's an Audi, not some CRX with a 1.5L vtec and a 3" exhaust that's painted 7 different colors. On that note though, a/c, P/S and windshield nozzel motors/res can go. sunroof motor/glass can go, alum./CF delete as a replacement. That's about another 100lbs off.
    Aug 07 2008
    White Rock
    Re: fastest ko3?
    yea so i guess thats our only option! BAMFT!
    Sep 17 2005
    Dublin
    Re: fastest ko3?
    Quote Originally Posted by Rhinop21 View Post
    Do you know if the st chip is 1 bar, or whatever they classify as stage 2, or what?
    2000 A4 1.8T
    1997 A4 1.8TQM
    Apr 22 2007
    Riverbank, Ca
    Re: fastest ko3?
    In order to go into the 13's on the stock KO3(without NOS) The following would be required IMHO.
    15" lightweight wheels w/ lightweight worn out hoosier fiberglass belted tires
    Fiberglass:
    Hood
    bumpers
    fenders
    doors
    Removed:
    interior-drivers seat and guages
    AC, power steering including everything.
    All power mods
    2.5" exhaust, no cat/muffler
    Custom tune for 22+psi running water injection
    Mike Hood driving.
    There.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: fastest ko3?
    I ran 14.6 @ 90mph on my k03 @ GIAC 21psi. 1.8 60' Full weight shit in the trunk and 200 dollar (set) champiro tires yeeeeah.
    I was going to try to break 13s with the new car, it already feels like it pulls harder than my old car WITH a boost leak. But its stock clutch, and I wont be going anywhere with that on a track.
    -18 718 GTS
    Mar 04 2008
    West linn, Oregon
    Re: fastest ko3?
    Quote Originally Posted by Militant-Grunt View Post
    1.8 60ft??? Come on now.
    1998 A4 sold
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: fastest ko3?
    Quote Originally Posted by blmlozz View Post
    I don't know about you, but I measured my spare tire. It's >1" smaller than stock tires, so it's useless to me. I don't even know where mine is anymore, I think it's still holding up my roommate's stock engine for his Miata.
    sunroof delete, empty out the trunk, there's a good 30-32" of bumper rebar that can be removed, remove rear seats, door panels, if you want to go nuts pull the window frame/regulators out, then move into the CF stuff.
    Mike Hood driving.
    Seriously? No offense to mike, but there are other drivers out there that can drive VAG cars. I'm not saying I could do better, but for damn sure I'll give it my best shot.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: fastest ko3?
    Lol, just run no exhaust after the DP, save some weight there too haha. Things can get pretty unrealistic if you think about it, then you wont have a car anymore,.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: fastest ko3?
    I could put a K03 on an R1, That would be a pretty quick K03.
    Apr 22 2007
    Riverbank, Ca
    Re: fastest ko3?
    He's a better driver than me :) And he's been doing it for a while...
    Fine how about if we just say Stig is driving?
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    Well this is what im thinking..
    -20+psi
    -mbc
    -2step
    -3" testpipe with electric cutout...
    -solid mounts
    -11lb flywheel
    -gutted trunk
    -ported/polished intake manifold and TB with manifold spacer
    -tip
    -710n
    -Then if required meth with lemi to up the timing
    -And if need be a K03S
    So you guys think a small fmic will help or hurt for this application?
    I already have the piping from a godspeed kit just need the actual fmic...
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    Re: fastest ko3?
    I know the FMIC will drop a couple psi but really it's lowering the IAT's. Plus besides I doubt the 22psi that some of us push (w/o an MBC) is totally beneficiary. As long as were at 18psi+ the FMIC will only help IMO. I gotta try this. Just gotta wait for the testpipe and IC and start stripping this B****. I got a weight at work for semi-tractors and I went from a recorded 3440lbs to a 3080. Removing everything unnecessary (including a couple hundred lbs of stereo) so I'm SURE a k03s can break into the high 13's.
    Mar 04 2008
    IL
    Re: fastest ko3?
    Think loading with 100 octane will help much?
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    not if you dont have a tune for it...
    Mar 04 2008
    IL
    Re: fastest ko3?
    Well I got the program but never got around to it this summer. I'd like to know what people gained on the dyno by putting 100 octane. I figure it'd be similar to W/M
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    How did you lose 360lbs? mainly subs/amps/ps3's?
    Apr 22 2007
    Riverbank, Ca
    Re: fastest ko3?
    You dont need a 2 step to launch a K03...
    Full throttle drop clutch @ 5k.
    Mar 04 2008
    IL
    Re: fastest ko3?
    Yeah, sub&box, amp, full size spare, lining on the trunk lid & hazard triangle, cd changer, tool kit, rear seats, f. passenger (weighed like 50lbs itself!) swapped 18's for 17'' lites, etc. this all took no more than an hour between 2 guys and just went racing around cornfields (I live in the boonies so not a danger to civilians) so I'm sure its worth it to hit the strip. 5-20 lbs here and there really add up. Although with no weight in the back I did feel it uneven so might not be as useful for autox as in a 1000'.
    Aug 16 2007
    Buffalo NY
    Re: fastest ko3?
    i also want the advantage of the no lift shift... And i cant build boost just dumping the clutch with a quick rev
