Results 1 to 6 of 6
    Aug 31 2008
    00 S4 Black 6-speed
    West Lafayette IN USA
    Misfire detected
    Hello guys.
    I have a question about misfire on cylinder.
    I went to firestone yesterday due to chech engine light is on.
    They did compurterized engine analysis.
    They said that misfire is detected on one cylinder.
    I dont know which one is.
    Because sprak plugs didn't change.
    That made one iginition coil got a problem.
    So i need to change these below
    -spark plugs
    -ignition coil
    what do you think about guys?
    Do i need to take some test before I change it?
    Thanks
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Misfire detected
    not sure exactly what you mean lots of words lol, but you can "test" it being a coilpack (ignition coil) by taking the coilpack off, (2 10mm bolts) and switching it to another cylinder to see if the misfire then follows to that cylinder. if it does, the CP is your problem. if not, then take it from there :)
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    are a few random/multiple cylinder misfires ok ? I clear them and they don't come back for a few weeks... and sometimes I get a few Cylinder 5: Misfire Detected... anything to seriously worry about ?
    My car is fast
    Oct 31 2005
    Ashburn
    Quote Originally Posted by IamEzraM View Post
    A CEL is there for a reason, anything that emits a CEL needs to be addressed so that it doesn't get worst. Try a search on coil packs, or misfires and there will be plenty of info to guide you to the right path for your problems.
    - Instagram: @Sinister_rs5-
    Jul 21 2005
    Bedford/MA
    these random misfire's haven't shown a CEL on my LCD display yet... I only see them because I log the engine codes via VAG-COM
    My car is fast
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    The same thing happened to me this weekend. It is as simple as changing a coil pack. ~$60
