Results 1 to 6 of 6
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Accelerator stuck
    This morning I turned left on a quiet street, and stepped on the accelerator, but as RPM's went up, I slipped the shifter back into "D" and suddenly realized that I "lost" the accelerator pedal. Almost felt like it got sucked to the floor and pulled away from my shoe.
    Within the next 10-15 or so seconds, the car continued accelerating as I first stepped on the brakes, but backed off as the engine was fighting the brakes, (and I don't care much for the feel of the stock brakes, so I was thinking it would not hold). I tried tapping the accelerator, but it would not come back up. The road ahead of me was clear, so I stuck my shoe on the side of the acc pedal and lifted it up, which worked. Probably got up to 50 or 60 by that time.
    I stopped, played with the acc pedal a bit and with all seeming well again, I went along my way. But what the hell happened? Not sure if the problem is mechanical, or perhaps something electronic causing the cruise or TB to accelerate. Cruise control was off though.
    Though I was calm thoughout the process, it was scary. Anyone here experienced this before? I know about Audi's history of unintended acceleration in the 80's, but this is a totally different car/engine/etc. I need to check if there are any codes etc.
    Cheers,
    -Neil.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Aug 03 2007
    2003 A4 1.8T QTip Sport Avant
    Denver
    Re: Accelerator stuck
    I've heard of that happening to a couple of people. Turned out it was their floormat that was pushing the pedal down. Check to make sure yours is fastened.
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Next time that happens, throw the car in neutral. Dont kill your brake pads. To get it fixed I would go to the dealership and ask about it. Also make sure theres nothing down there that gets stuck.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    May 26 2005
    CLS63tt
    Boston
    that sucks
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    That happened to me once when I was reversing. I went into neutral, turned the car off, pulled the accelerator up and it's never happened again.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    It happened to a friend of mine in a B7... His problem was electronics since his accelerator had movement as normal but the car was WOT! Almost wrecked his car but was able to get the under control. Dealer told him that they had no clue on what had happened or how to fix it since the car had no signs of any problem. So a week later he trade the car in for an SUV. He studied in Purdue University, so his dealer was somewhere near...
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
