Results 1 to 6 of 6
    Veteran Member Three Rings Outkasted's Avatar
    Feb 12 2004
    01 986 Boxster/ Unrestricted Hayabusa
    coilover question
    I have a quick question and want to make sure i am right. Koni coilovers from a 2000 1.8T quattro will fit on a 2002 s4 but the spring rates are not correct. So coilovers will also fit in reverse from the s4 to the 1.8T. Just want to be sure i have i correct. i did a search and could not find a specific thread stating the answer.
    Always looking for the next project
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Re: coilover question
    In theory yes. They're just set up differently for the added weight (to my knowledge), so the S4 being heavier would have a stronger spring for the increased weight. So decreasing the weight wouldn't have any harm.
    But I could be wrong.
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    Quote Originally Posted by gmann View Post
    i would say its right..call company and they will tell you if they will fit..they wont tell you if they will work due to liability..if they " fit" then yes because i have a6 avant coilovers on my a6 4.2 sedan..=D
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Koni does not list coilovers for B5 S4, but the B5 A4 ones will fit, and STaSIS uses them for their kit. Spring rates are ~400 lb/in all around.
    As one tends toward higher performance suspensions in these cars, rear spring rates become higher than the fronts to increase rear roll stiffness, which allows a balanced setup like the Konis to work for eith ap.
    Having used Konis before, I'd recommend buying the STaSIS SS setup, which for $100 extra gets damping set up on their shock dyno, and delrin spacers that allow the perches to be adjusted on the car. Regular Konis are near impossible to adjust ride height while installed.
    "Obsessed" is a word that the lazy use to describe the committed.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    there are 2 types of coilovers that fit the b5. ones made for quattro and ones made for FWD.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by ThirdStrike View Post
    2nd that and teh spring rat eis were it is different from what I know
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
