Results 1 to 11 of 11
    Established Member Two Rings Two A's's Avatar
    Sep 19 2008
    3 A4's, 1 Q7, 1 porsche 911
    Cary, NC
    Depo Head Lights
    Has anyone ever heard of these or have them?I purchased some for my 97 to replace my two piece headlights and I noticed the wiring is a little different.
    The green machine money pit
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: Depo Head Lights
    Quote Originally Posted by Two A's View Post
    you also have to trim your front fenders for them to fit i beleive
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Established Member Two Rings trevor303's Avatar
    Apr 06 2008
    98.5 A4 2.8
    Littleton/FoCo, Colorado
    you have to trim if you are going from 2piece to 1piece, and as far as i know, depo doesnt make 1pcs (could be wrong though)
    the difference in wiring may be because the depo housings don't have fog lights, and have city lights instead. i actually had a wire pull out of one of my housings when i bought them, and ended up just pulling the plugs/wires to lights from one of my old ones and putting it in
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    If only we had a search button
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    They make both 1 and 2 piece lights.
    The wiring between ALL one and 2 piece OEM style lights is different.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    You may have to re-use your old bulb holder for the signal lights. Also you'll lose your fogs since these have city lights instead.
    Apr 01 2007
    Irvine
    If you go 2-piece to 2-piece, the wiring stays exactly the same.
    Mine have held up well except that the driver side turn signal fogs up occasionally.
    May 12 2007
    MN
    Quote Originally Posted by crono35 View Post
    If you re-use your old bulb holder for the signal lights. That's how mine was anyway. The bulb holders that came with the depos had a different end on them.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by Stampy View Post
    That would be real nice.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    you need the wiring harness.
    http://www.ecstuning.com/stage/edpd/...egory=Lighting
    http://www.ecstuning.com/stage/edpd/...viewimage.html
    I did it a couple months ago and you need a dremel to cut the fenders.
    Heres a DIY
    http://www.audiworld.com/tech/elec88.shtml
    Sep 19 2008
    Cary, NC
    Quote Originally Posted by jrock View Post
    Heres a DIY
    I will have to have a go at this on the weekend. Thanks for the info.
