Results 1 to 12 of 12
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Where can I get this IC hose? (marine?)
    I remember there being an update on what alternative flexible piping there was and I saw this on the mian AZ page.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Where can I get this IC hose? (marine?)
    Why would you want flexible piping? It isn't going to give you the best flow since it will have ridges on the inside.
    BTW its called Water Discharge hose.
    Jun 04 2007
    Austin/DFW, TX
    How much worse is the flow?
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    socal
    Quote Originally Posted by biketsai View Post
    Not sure but nothing is going to be better then a very smooth surface, any bumps will cause a turbulance and you want as little of those as possible.
    Jun 04 2007
    Austin/DFW, TX
    Thanks Mike
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    im pretty sure you can get flexible tubing that is smooth inside with a wire wrapping outside for rigidity. i actually have one at my house for use with a water pump
    Jun 30 2007
    Raleigh, NC
    the stuff on ravi's car is NOT water discharge piping that you get from lowes...
    it's marine exhaust hose and is EXTREMELY tough stuff. (very thick rubber-type material with a medium gauge wire spiraled around it) it may or may not be flexible enough for your application. The inside isn't entirely smooth like mike said, but the upside to that stuff is that when it compresses on the inside of the bend it doesn't kink up as much - instead it kind of... "squishes"
    hard to explain - if you had a section in your own two hands to play with it'd make more sense
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 04 2007
    Austin/DFW, TX
    So what do yall think of finding marine piping that is smooth?
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    socal
    Vetus Exhaust Hose and it is not cheap. 2.5" ID hose 6 ft long is $108.
    I would still pick hard pipe over any type of hose.
    Jun 04 2007
    Austin/DFW, TX
    Lol ill pass on that $108. I guess ill stop being lazy and fix my IC piping
    My 5-Speed Swap DIY
    - B6 USP
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    just because its rigid on the outside doesnt mean its not smooth inside. Its just rigid so when its bent there are no creases.
    "slow is smooth and smooth is fast"
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Airflow will be slightly better through the hose than most tubes. There just aren't any restrictions, gaps, or steps in the middle of it like you get from couplers or welds. It is the equivalent of perfect mandrel bent tubing.
    Jim
    I Do Werk.
