    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    help, when I press in the clutch it doesn't feel right
    when I press in the clutch pedal it feels very vibration ish. I noticed this mornig that there was a squeking sound, I pressed the clutch pedal down and the noise went away. Was driving fine afterwards. Engages fine. Did my throwout bearing take a dump? Any other ideas? Thanks
    Feb 14 2004
    S Ã C, CÃ*
    Re: help, when I press in the clutch it doesn't feel right
    any suggestions?
    Veteran Member Three Rings EuroTrash A4 NY's Avatar
    black B6
    New York
    master slave cylender
    ~2002 A4 1.8T~Black.on.Platnum~USP Front~S4 Grille/Black Rings~19" RS4 Reps Custom Painted Bronze/Falkin 452~Carbonio V.2 Intake~Decorsa Street Exhaust~ER Sport FMIC~Forge 007~OEM RS4 Rear Sway Bar~Stasis Street Sport Coilovers~Yakima Roof Rack~
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    what brake fluid are you using? I heard ATE Super Blue sometimes makes noise.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by Sick B6 View Post
    Any quick way to verify them? when i press the clutch in with the car off it feels fine. As the rpms increase it feels worse. It seems when i get into first the car is "chattering" when it engages.
    thanks!
