Results 1 to 6 of 6
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    Need help asap on clear corner mod!!!!!!!!!!!!!!!!!
    i can't get the extension to line up to the 3rd screw in the headlight... any tips? i tried aligning it with our fingers.. we can touch the top of the screw but the bit doesn't reach. wtf? it touches the tip of the screw and thats it. i've been at it for the past hour. both sides are like this.
    i've tried both 25 and 30.. i'm assuming it's the 30 torx bit right?
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    Re: Need help asap on clear corner mod!!!!!!!!!!!!!!!!!
    If its not long enough then its not long enough... you cant make it longer. But if you have a flathead that is longer it will also work. That is what I use. The flathead can fit inside the wedges of that screw and it works just as well.
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Dec 27 2005
    Ft lauderdale
    nvmd.. it's was a damm allen. wonder why all the diy said torx.
    Dec 27 2005
    Ft lauderdale
    umm actually now that i look at it... it was a torx, don't know why the allen worked and the torx didnt. damm what a waste of an hour
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Quote Originally Posted by snosk8tr123 View Post
    2nd. I used a flathead for mine too. I found it a lot easier to get lined up...
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Dec 27 2005
    Ft lauderdale
    damm what a bitch that was. after the debacle with that screw, then came the amber lens caps. first one was a breeze... just stuck a screw driver from the back and popped it out. the second one wouldn't budge. the chrome plastic around it kept coming off with it. after drilling holes and playing with it for awhile.. we finally got it off but chipped a tiny chrome piece off the circular area right where the bulb comes in from and a few smears from trying to wipe fingerprints off. ahh well, its not noticeable once put together and looks great. the amber bulbs i got from xenonmods doesn't match my sidemarkers though.. it's almost red/orange. good thing it'll only come on for turnsignals.
    oh and instead of using the oven cuz i was at my buddy's shop.. i just used a heat gun for only a few minutes and it seperated easily.
