Results 1 to 4 of 4
    Veteran Member Three Rings sickspeed's Avatar
    Sep 12 2005
    2001 S8 and 2011 Q7 TDI and 2010 Toyota Land Cruiser
    MD
    Can't decide between Koni or Bilstein Sport or Koni FSD shocks...
    i have a B7 avant and i am changing the suspension front stock sport to neuspeed sport springs and i cant decide on which shocks. anyone have a good/bad experience or recommendation on any of these? id like the car a bit lower with improved handling but i want to be careful i dont end up with a super harsh or bumpy ride.
    thanks
    Deactivated Three Rings
    Apr 11 2008
    Re: Can't decide between Koni or Bilstein Sport or Koni FSD shocks...
    Just the front? Did I read that correctly? I'd go with the FSD's if you want adjustability and a softer ride. Bilstein for more grip. I went from sport suspension to bilstein/H&R and it was a tad more 'bumpy' but nothing that made me regret the awesome handling. Simple fact is that the stiffer your spring/shock combo is, the more bumpy your ride will be. BUT, it turns on a dime with my sway bar upgrade..
    Jun 13 2008
    02 b5.5
    fsd are not adjustable.. i had them on a passat they were like stock but tight around turns
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    I had FSD they are good if you don’t want a harsh set up. They also have a kit that come with eibach springs if you want it lower than stock ride height. Hope this helps.
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
