Results 1 to 10 of 10
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Rear end fairly bouncy...
    Setup = H&R Sport Springs with Bilstein Sport Struts, just over a year old - 10,000 miles.
    Lately my rear end has felt pretty bouncy going down the road... actually for the past few months... just really picked up on it when my dad drove my car and said something about it.
    Being the struts are pretty new and im only on a very mild drop, they SHOULDNT be bad... but I guess anything is possible. Anyone know what the warranty is like on these struts?
    Is there something else that can make the rear end bouncy, like bad bushings??
    Any help is appreciated!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Rear end fairly bouncy...
    Bad shock im guessing. I could be defective
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 30 2007
    Upstate, NY
    Its not one side or the other, the whole rear end is bouncy... push down on each side of the car in the rear and it dosent just settle back up, it bounces a little... same on both sides.
    I emailed Bilstein, we'll see what happens.... this is my only car, so I cant take the struts out... send them away... and wait. I need my car.
    Sep 30 2007
    Upstate, NY
    Also... it seems the rear end has always sat lower than the front... since the new suspension. I'd like the front end a tad bit lower to match the rear...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Contact Bilstein because your shocks have a life time warranty. If you have the height adjustable rears you could just raise the rears up 1 notch, the H&R's have always caused the rear to sit lower then the fronts.
    Sep 30 2007
    Upstate, NY
    Good to know. No height adjustments here... I was thinking of cutting a half-inch off the bottom of each front strut to make things more even. Either that or there is a local guy willing to throw them in a lathe and make another notch.
    What other springs would give me a sililar drop but be more even?
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    i would put some H&R race springs on the bilsteins. that would give you more of a drop. But first things first, make sure its not the bilsteins that need replacing.
    "slow is smooth and smooth is fast"
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    H&R Race would drop it more but it would drop the same front and rear which doesn't fix the rake issue. I'd have the notches cut. Be sure that he measures the notch depth carefully before cutting.
    Have you checked to see if anything is loose back there? Any funny noises or anything else strange? It is unlikely that both rear struts blew at the same time. My old Jetta had the same set of Bilsteins for over a quarter million miles without a problem. Didn't even start autocrossing it competitively until over 252k miles.
    Jim
    I Do Werk.
    Sep 30 2007
    Upstate, NY
    there are a few slight noises back there... which makes me think the bushings are worn out... but the way it bounces back up when pushed down says the struts are bad.
    I also find it strange that both would go... it always had a soft ride... just never really picked up on the bounce...
    my response from bilstein was full of questions... seems like this wont be all that easy.
    Nov 15 2007
    Audi A4
    Redding, California
    I have bilstein/neuspeed race springs....ride height is perfect....no bouncing at all and it feels amazing anywhere....
    I am guessing you have a rake issue...the front of the car should not sit higher than the rear....
