Page 1 of 3 123 LastLast
Results 1 to 40 of 95
    Jan 01 2008
    Long Island NY
    The Results are!!!!
    I did 3 runs 1/4 Tank of 93 Octane, 50PSI in the Tires. No spare but everything else in the car. 1st run was 1500RPM Launch, 2nd Run was 3500 RPM Launch, 3rd Run was no Launch car shifted while power braking had to let off then pin it sucked b/c i was just about to launch hard as shit.
    1ST Run:
    R/T .538
    60' 2.030
    330' 6.025
    1/8 9.348
    MPH 73.84
    1000 12.209
    1/4 14.612
    MPH 93.32
    2ND Run:
    R/T .773
    60' 1.919
    330' 5.841
    1/8 9.173
    MPH 73.71
    1000 12.935
    1/4 14.429
    MPH 93.02
    3RD Run:
    R/T 1.493
    60' 2.475
    330' 6.492
    1/8 9.850
    MPH 73.62
    1000 12.712
    1/4 15.109
    MPH 92.51
    Jan 01 2008
    Long Island NY
    Re: The Results are!!!!
    BTW it was 67 Degrees out and the car weighed 3650 with me in it so 3400 without me. BHVDR i will scan the time slip later going out to eat now:)
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    2nd run look great! i'd imagine with better launches your times would def improve.
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    The second run was pretty good.
    I didn't know that launching a car could really make that big of a difference...
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by Auditude2.0T View Post
    1ST Run:
    R/T .538
    60' 2.030
    330' 6.025
    1/8 9.348
    MPH 73.84
    1000 12.209
    1/4 14.612
    MPH 93.32
    2ND Run:
    R/T .133
    60' 2.160
    330' 5.971
    1/8 9.071
    MPH 79.84
    1000 11.694
    1/4 13.893
    MPH 101.33
    3RD Run:
    R/T 1.493
    60' 2.475
    330' 6.492
    1/8 9.850
    MPH 73.62
    1000 12.712
    1/4 15.109
    MPH 92.51
    13.9 is fast. I wonder how fast you'd be on 100 octane.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Not bad for your first time. Well, you broke into the 13's which is what you wanted to do.
    Do you still have your 17" stockers? If they are lighter than your current set-up may wanna consider a run with them.
    Its alot tougher when you are actually there on the line at the light, isn't it? 10x tougher with a manual esp if you are a 1/4 mile noob.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Jan 01 2008
    Long Island NY
    help yeah I was nervous
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Did you weigh the car or are you guessing?? Because the way your car is set up from your sig. suggests that the car alone should weigh in the 3650-3700 lbs range.
    I'm assuming you didn't gut it from your first post??
    Just wondering cuz our cars' curb weight is 3660 lbs and 300lbs is worth a couple tenths of a second or more.
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Jan 01 2008
    Long Island NY
    I weighed it it was actually 3642 with me in it and I weigh 255
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Quote Originally Posted by swoardrider View Post
    Motortrend says 3,450lbs click
    -Kris
    Dec 11 2006
    Boston
    Nice time on the 2nd run.
    Work on that launch and you will see some better times.
    Stage 3+ RS6's
    Oct 29 2007
    So. California
    2nd run was nice. Now go back to the track and get that 60' down and I think you can get another tenth or two.
    Jul 21 2004
    South Florida
    Send me a digitial photo of your timeslips and your mods and i'll put you in the database...
    http://www.mjbmotorsport.com/sitebui...medatabase.htm
    2018 Audi S5
    Gone-
    Jan 01 2008
    Long Island NY
    Right Lane.
    [email protected]. APR 93/AWE Exhaust/Testpipe/FMIC/APR FSI Pump/CAI
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Sweet! Congrats on breaking the 13's...
    Jan 01 2008
    Long Island NY
    Im going back in two weeks. By then i will have APR 100, ECS Power Pulley, Labree DP and maybe a Dump Valve.
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Quote Originally Posted by IceMole View Post
    Edmunds says 3,660lbs http://www.edmunds.com/new/2008/audi...875/specs.html
    I believe 3,450lbs is for the FWD model. At least that what Edmunds has the FWD listed as.
    '06 2.0T S-line Tip
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    mmm....interesing. I wonder if the scale you were using was off.
    I've weighed my car with the spare but without me in it and it came in at 3700lbs at a public scale the first time. The second time I weighed it was at the race set-up shop when I had the car corner-weighted. It came in at 3850lbs without the spare and with 180lbs worth of my weight in the driver's seat.
    We both have the same base model cars with the exception of different modded parts. In theory I would think they would be within 50lbs of each other??
    '06 2.0T S-line Tip
    Jan 01 2008
    Long Island NY
    The scale was definently not off.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    good stuff! you broke into the 13s... next time take out your rear seats and use 100oct!
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    2ND Run:
    R/T .133
    60' 2.160
    330' 5.971
    1/8 9.071
    MPH 79.84
    1000 11.694
    1/4 13.893
    MPH 101.33
    Congrats! you can run much quicker than that. I run a 1.907 60FT and ran a 14.1. You are now king! Are you going to make the swich to Revo? I am very soon.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Jan 01 2008
    Long Island NY
    Im sending APR Data Logs they want to fix my program.
    Jul 21 2004
    South Florida
    Do you have scans of your other runs?
    thanks,
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    congrats dude! i will be posting time slips in about a month after fixxfest
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Aug 08 2008
    2017 Q5
    Houston, TX
    i want to race. =T
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Nice times. Improve the 60' and you'll see even better numbers. Now you just need to strap it to a dyno...I'm very interested to see what the car puts down..
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    an awesome run/time!
    congrats!
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Established Member Two Rings virgsa4's Avatar
    May 02 2008
    14 S5 6mt
    Chicago
    Great job!!!
    Makes me wanna take mine now (stock 6sp) I would be happy with a high 14 - low 15 time though.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Anyone know how to remove the rear seat bottoms?
    Or the rear seat backs if you have heated seats?
    I removed the backs of mine when I took off my rear bumper, but the wires for the heating elements were still restraining them and I didn't see a harness to unplug...
    Ignorance is bliss.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Nice job, now you have some numbers for the haters lol
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Ih8OEM View Post
    Nuff said.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    I dont believe it.
    Your real time was on the left.
    Ill race you October 19th for show and go.
    Thats if you are up for showing your real times.
    You have an Auto and there is not such thing as reving it up
    and dumping the clutch, so your 60' is going to be the same basically all the time.
    Dont really care how you defend yourself, but you cant bullshit a bullshit artist.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    ^ wow ? pretty big accusation with not a lot to back it up other than 'i just plain out dont believe you'
    Jul 21 2004
    South Florida
    He's probably pointing out the large discrepency in trap speeds.
    The OP trapped abut 93mph on two of his runs, then 101mph on his best run (that ticket just happens to have a 93mph trap speed time in the lane next to him).
    Trap speed is a good indicator of the power your making and even if you completely flub a launch, you should be somewhat consistent with trap speed. Going from 93mph to 101mph in trap speed would require an increase of 100hp or more. It's odd is all. It's also odd because he got an even better launch on one of his 14.xx second times with a 93mph trap speed yet with a worse launch gained 8mph in trap speed and dropped his 1/4 mile time.
    1ST Run:
    R/T .538
    60' 2.030 <---------- BEST LAUNCH
    330' 6.025
    1/8 9.348
    MPH 73.84
    1000 12.209
    1/4 14.612
    MPH 93.32 <-------TRAP SPEED - INDICATOR OF POWER
    2ND Run (right lane car from timeslip):
    R/T .133
    60' 2.160 <-------------- MEDIUM LAUNCH
    330' 5.971
    1/8 9.071
    MPH 79.84
    1000 11.694
    1/4 13.893
    MPH 101.33 <--------TRAP SPEED - INDICATOR OF POWER
    3RD Run:
    R/T 1.493
    60' 2.475 <---------WORST LAUNCH
    330' 6.492
    1/8 9.850
    MPH 73.62
    1000 12.712
    1/4 15.109
    MPH 92.51 <--------TRAP SPEED - INDICATOR OF POWER
    As you can see above, even with the best launch versus the worst lanuch the trap speed changed less than 1mph. The 1/4 mile time is what changed and it changed by a half second...significant and what you'd expect from launching better or poorer.
    But the center run (the best run) shows an altogether MUCH faster car. It launches poorer then the first run yet still is bundles faster in trap speed at the 1/8 mile mark and at the 1/4 mile mark.
    It could be that for some reason he hit the brakes at the end of the tracks lights on the 93mph runs.
    Now, if you substite in the left lane car from his winning ticket the three runs would look like this...
    1ST Run:
    R/T .538
    60' 2.030 <---------- MEDIUM LAUNCH
    330' 6.025
    1/8 9.348
    MPH 73.84
    1000 12.209
    1/4 14.612
    2ND Run (left lane car from timeslip):
    R/T .773
    60' 1.919<-------------- BEST LAUNCH
    330' 5.841
    1/8 9.173
    MPH 73.71
    1000 12.935
    1/4 14.429
    MPH 93.02 <--------TRAP SPEED - INDICATOR OF POWER
    3RD Run:
    R/T 1.493
    330' 6.492
    1/8 9.850
    MPH 73.62
    1000 12.712
    1/4 15.109
    THe above runs now make sense. He gets the best 1/4 mile time on the run with the best launch. The trap speeds which are indicators or power all stay within 1mph of each other.
    Not saying that is what happened, but it simply appears that way from the objective numbers.
    It would help just to post the two other time slip photos. I think that would remove any doubt. It's not as though it's out of the realm that a fuel pumped car could go that good time.
    cheers! Mike
    2018 Audi S5
    Gone-
    Jan 01 2008
    Long Island NY
    That was my time LOL I'm running the car again at show n go
    Jul 21 2004
    South Florida
    I can see maybe you lifted right at the end of the track on the other ones. Do you have a photo of the other slips?
    2018 Audi S5
    Gone-
    Sep 24 2007
    Dallas
    Quote Originally Posted by turbo4s View Post
    I dont believe it.
    You really dont know much at all do you???????????? With the Tip we can rev up to 3500 RPM's and unlike a standard we build boost the longer it stays there. The 60'ft is not always the same I have run from 2.1's to 1.83's. Before you flame somebody get your facts straight. Oh maybe its you suck at driving and cant believe somebody can get into the 13's.
    Jan 01 2008
    Long Island NY
    I dont believe it.
    whatever you say bud. So your a bull shit artist i see. Because you said you i can't bullshit a bullshit artist. No need to be hating.
    May 20 2004
    More cars
    Never Land Ranch
    I'm going to laugh when the B7 S4 gets taken by the B7 4cly!
    2.0T > 4.2
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Sep 24 2007
    Dallas
    Quote Originally Posted by SEXICAN View Post
    2.0T > 4.2
    I have done it several times to a B7 S4 tip
