Results 1 to 32 of 32
    Senior Member Two Rings ClayFighter's Avatar
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    B6 S4's with StartupRacing Votgland GT's
    I need your help. My car has been at the shop for 3 days. Anyone with this setup have issues with the front ride height? I have BBS LM's wrapped in 245/35/19 Michelins et 32. I can't get ANY wheel gap. Wheels are tucked to the point where fender rolling and maybe even camber adjustment will be required just to turn the wheel. The perches have been raised so far, that a spring compressor was necessary.
    Please chime in with thoughts or setups with pics.
    Dec 05 2006
    So. Cal.
    Re: B6 S4's with StartupRacing Votgland GT's
    Hey Clay, what is going on? Can you provide any pics? I am not familiar with the Vogtlands but something doesn't sound right. You shouldn't need to roll anything to get these wheels and tires to fit. The worked perfectly on my B6.
    My ride height was set at 25.75 in the front and there was no rubbing at all.
    post some pics if possible.
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Yeah waiting for the shop to forward me the pics. I have no idea what's going on. My guess (without taking measurements) is that the highest setting I can achieve is going to be around 24-24.25 --> again that's a GUESS. This setting also means the springs are compressed ALOT with the car lifted, let alone when it's on the ground.
    I've opened up communications with the shop and Startup Racing to try to get some answers. The shop is saying that there's something wrong with the setup, SUP is saying there's something wrong with the install. All part numbers match and with pics being sent back and forth, installation appears to be correct.
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    pics of how they are installed and we can figure it out.
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Perch setting and resulting ride height.
    Raising the perch as per SUP's instructions over the phone
    ^ see how high the perch is? that's the highest I can raise the car?
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    That's strange! I haven't had that issue?!
    Call Tomasz at Startup and see what he says...
    Good luck!
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Oct 11 2007
    make sure the shop that installed them has the strut mounts fully tightened down, but from what i can see it looks close to spec
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    any other thoughts or input?
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    By the pics you posted they look normal?! There could be some defect which is why you should call Tomasz or Mike at SR.
    1.425.996.7302
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Quoted from the Group Buy thread:
    "Since ride height is totally adjustable, you get to select your drop level, from higher to stock, to riding on the ground (highly not recommended)."
    - I cannot achieve anything close to OEM height... which looked like this:
    We have spoken to both Mike and Tomasz and they say I'm the first one to have an issue like this. Mike says, "I can tell you 100% you have a working product, that is proper for your car."
    I'd just like to get some confirmation from existing users (which is seemingly hard to find even though SUP has sold "thousands of these kits"). If anyone has pics of their install with the tire off showing their perch settings as well, PLEASE chime in! Thank you AZ!
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Quote Originally Posted by ClayFighter View Post
    I'll try and get you some pics...
    That sucks to hear. Actually PM Stevelev. He should have pics of the wheels off showing what your looking for.
    Dec 05 2006
    So. Cal.
    That stock pic actually looks great.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Sorry to hear you're having issues. My mechanic didn't have any issues with getting the ride height dialed in to 25.5". If you send me an email, I'll respond with the pics my mechanic took when installing them on my car (too lazy to get them hosted up prior to then posting them up here). I hope you can get this sorted out ASAP.
    Cheers !
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Established Member Two Rings toneloc's Avatar
    Jul 08 2008
    none
    SO/CAL
    seems like u got the fronts as high as i was able to get mines using those cheap spring clamps from auto zone..i can't get them any higher without taking them off and using a machine spring compressor but that would defeat the purpose of coilovers and me adjusting my ride height to desire.. my fronts are around 38 rings..ride is not bad..but driver side rubs fender wall when i hit dips..i just need about 2 more rings clear and i'm happy..sometimes clay i think this setup was made for both a4/s4..and not specificly for s4..
    deval splitter.from EUROGEAR.installed by AUTOWERKS
    HRE 441R 19x8.5x35x245..thank STEVEN.
    vogtland GT coilovers.STARTUPRACING.. installed by CHARLIE
    RS4 blk optic grill n plates.. TM TUNING
    RS4 Bumper..EUROGEAR..painted installed by AUTOWERKS
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Thanks for the pics Steve. Your perch settings are set lower than mine yet you have much more wheel "gap" than I do. I had envisioned a setup quite similar to yours when I purchased these and am still confused why mine are so different.
    Here are Steve's perch settings and the car's stance:
    Steve's Volks are 19 x 8.5 (ET 35) with 235/35/19’s Hankook K104’s
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Quote Originally Posted by toneloc View Post
    Hey Toan,
    No way would I try to get the springs compressed enough using cheap units from auto zone! The shop has their compressor.
    We've brought to SUP's attention our concerns regarding the cross compatibility of this set up and they insist they haven't had any problems with S4's. (Steve's car being a prime example) But something isn't right. BTW thanks for sending me pics and offering your feedback. Your emails are helpful!
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Hey Toan,
    I still don't understand the cross compatability: B6 A4 w/ 1.8T or 2.8 versus S4 w/ V8, S4 would be heavier, needing different ( stiffer ) spring rates to prevent something like this.
    Registered Member Two Rings hackers4's Avatar
    Jun 12 2007
    Miami, Fl
    It definitely sounds like spring rates are the problem. I don't even think riding with the perches that high is safe. There is a maximum height the perch should be at. I would ask for written instructions, most manufacturers can provide, and that illustrates maxumum and minimum measurements ON the coilover. i.e. from the bottom of the coilover unit to where the perch sits. Where it is sitting now does not look safe at all.
    2005 Audi S4
    MTM Fullback Exhaust
    ASR Engineering Test Pipes
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stasis Center Differential
    Stratmosphere SS
    BBS RS-GTs
    Jul 08 2008
    none
    SO/CAL
    dunno any1 else having problems as "clayfighter" and i have had with these C/O..set up..there is no way i will be able to drive on a track with the rubbing on tight turns with the height i am able to get at the moment..steve S4 avant looks perfect to the height i was looking for..i'm running 245/35/19 et41R et44F wheels..
    Jul 08 2008
    none
    SO/CAL
    Quote Originally Posted by hackers4 View Post
    thats what my boys n i was also thinking.. spring rates might be off a4/s4 same setup but diff spring rates due to s4 being alot heavier.. any imput would be appreciated thank..
    Jun 12 2007
    Miami, Fl
    To begin with, spring kits for the A4 and S4 are totally different, let alone coilover kits. If part numbers are the same, that's not a great thing at all. The cars are completely different weights and, because of that, different weight distribution. Really not sure what to tell you and why you are getting an answer saying that A4 and S4 suspension components are interchangeable; they aren't.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Apr 27 2004
    Actually, The Startup GT coils aren't the only setup that use the same setup for both A4's and S4's. The Vogtlands that Puremotorsport sells are the same for both cars (makes sense since they are also made by Vogtland and BTW the regular Vogts use spring rates that are softer in front by 25-50 lbs compared to Startup's version). I'm pretty sure that there is another manufacturer or two that does this as well.
    Mine are working great and here's shot or two to prove it:
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Jul 08 2008
    none
    SO/CAL
    i wish i could get that ride height on my car.. it be a dream..actually i was in with a g/b for koni c/o..and the guy told me it will fit on my car but i would have to adjust springs n dampers since s4 are heavier than a4 so i cancel the order..n got votgland gt..
    Jun 12 2007
    Miami, Fl
    Honestly, I don't have any experience with Vogtland's suspension products. However, I do know that H&R and Bilstein do thorough testing of their products and do not have the same part numbers for A4 and S4 suspension offerings.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Jul 08 2008
    none
    SO/CAL
    wells i have raised my car the highest i can with out taking to a shop.. have to take it there soon since i need about another 1/2 inch f/r.. any updates CLAY?
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Update?
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Moved the perch to the very top. Took car out for a test drive and still experiencing rubbing even while driving straight. Going to call Tomasz and see if he'll honor me a refund as we cannot get this application to work for us. I understand both Mike and Tomasz are great guys with an excellent reputation so I'm hoping they'll do me a solid and allow me to return these.
    Dec 05 2006
    So. Cal.
    Clay, watch the rubbing as you're gonna ruin those beautiful tires. They cost a fortune to replace. How are the wheels and tires doing anyways?
    Aug 01 2008
    Black 2004 S4
    Bay Area - Lahaina
    Still loving them, thanks for asking We only drove around the block before pulling back into the shop.
    I'm getting the OEM suspension put back on. There's just no way this setup is going to work out.
    Jul 08 2008
    none
    SO/CAL
    hey clay any update ??
    Veteran Member Three Rings dsq's Avatar
    Aug 10 2007
    B6 1.8TQM
    toronto
    i have the GT's for the b6 a4 sedan and the b6 s4 avant, both cars have no issues with height adjustment.
    | bbs | vogtland | giac | racetec | alcon | and more |
    in the rare event of an erection lasting more than 4 hours, seek immediate medical help to avoid long-term injury.
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    I have the vogtlads on my s4 avant. no problem with ride height. and i have a lot of thread left in both directions. sitting about 25 1/8 in the front
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
