Results 1 to 7 of 7
    Established Member Two Rings dvandentop's Avatar
    Jan 01 2008
    South Dakota
    labor cost to change clutch in 04 s4?
    anyone know the usual rate to change a clutch in an 04 s4 avant? mine is starting to slip
    Derek
    2006 Z06
    2009 cts-v
    2012 S4
    Registered Member Two Rings
    Aug 07 2008
    '04 B6 S4 - Dolphin Grey
    Collegeville, PA
    Re: labor cost to change clutch in 04 s4?
    I'm in the same boat. If you search through the first few pages you should see another thread about this topic. Most dealers in my area are getting around $1,700 for labor. Your independents are probably closer to $1,000 depending on their hourly rates. Apparently it's a 20 something hour job. Or at least that's what it pays to do it. Add in another $1,000 for parts if you replace the flywheel.
    Jan 01 2008
    South Dakota
    wow you sure man i know the b5 tt s4 was a pain to change the clutch i was told this one was supposed to be easier :eek:
    Derek
    2006 Z06
    2009 cts-v
    2012 S4
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Quote Originally Posted by DapperD View Post
    please stop spreading mis-information. Clutch job in a v8 s4 is not a 20something hour job, its more like 6-8 hours max. and i know this because that is what the general manager @ the dealership told me. other dealers will write more hours so that they can make more on the job.
    and as far as parts, spec and southbend make clutch setups for our cars. although ive most recently heard that southbend can nolonger source the parts for the clutches, however they can modify a stock clutch for $250 that will essentially make it a stg 4 setup.
    If you shop online you can find the stock clutch components for around $500 or less, and the flywheel doesnt have to be replaced, just resurfaced.
    Established Member Two Rings bakos4's Avatar
    Dec 13 2006
    1965 Squareback
    bakersfield
    dealership quoted me $3600. Went aftermarket stg3 and it was 1800 out the door
    RS5 Phantom Black, Loaded / AWE Exhaust Non Res Downpipes/ KW HAS/ HRE P104 Satin Bronze/ V1 hardwired/ Blinder Jammer/ Itg Filters/ Ecodes/ Suntek Wrap/ SPC Control Arms/ Calipers Painted Red
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Just had it done at an independent shop. They charged me 10 hours labor at $65 per hour, but it was his first V8 S4 clutch job (thats $650 for the math challenged). I imagine next time it will be between 6-8 hrs labor as some others have reported.
    After market stage III was under $1350 when everything was done. (650 labor, 400 oem clutch parts, 300 soutbend clutch parts upgrade + flywheel resurface).
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Jan 01 2008
    South Dakota
    where is a good place to search for a stock type clutch, i have my z06 for my go fast needs. dont have any mods on the s4.
    thanks
    Derek
    2006 Z06
    2009 cts-v
    2012 S4
