Results 1 to 9 of 9
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    B5 s4 suspension grease points
    On the b5 s4 where are the greasepoints located at.... stuff is starting to squeak so I was thinking about pumping some sinthetic grease in all the grease zercs I could find down there.... but I need help fiding them, lol
    thanks
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Re: B5 s4 suspension grease points
    Time to buy a control arm set. The bushings in your suspension are bonded in and twist instead of rotating. No grease. When things get creaky, it's time to replace.
    "Obsessed" is a word that the lazy use to describe the committed.
    Feb 22 2007
    Earth
    i understand.. but replace equals lots of money... thats not the point though.. are there any grease zerks on the b5 front end that I can pump with grease or not.. if yes, where are they?
    Aug 11 2008
    Austin, TX
    Quote Originally Posted by audimeister View Post
    No grease. As in, "there are no grease fittings".
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    hope you got about $1200 in the bank
    My car is fast
    Aug 06 2008
    Canadia
    ECS seems to have a pretty killer deal for the front control arms, $540, all febi stuff with outer tie rods and new hardware.
    http://www.ecstuning.com/stage/edpd/...S4&engine=2.7T
    just make sure the suspension is compressed when you tighten everything down or the bushings bind excessivley and you'll really shorten their life.
    Aug 06 2008
    Canadia
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Their kit is identical to this one we carry, for much less!
    Febi Control Arm Kit
    Feb 22 2007
    Earth
    i'll probably end up doing coil overs and arms at the same time.. just give me some time to recover from rims and tires, lol
