Results 1 to 25 of 25
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    Turbo kit based on Garret GT2860RS for 2.0 TFSI
    I've got conversation with local dealer, they propose me to install Garret RS turbo with custom made(full race manifold), FMIC(I gues AWE, but it depends), injectors and fuel pump.
    The RS have chosen(2871 much slower on low rpms) because it smaller and has more hp and tg on low rpm.
    The limit of RS is obout 360 hp, my dealer sad that if I'm not going to low engine resource a lot I shouldn’t make more than 320 hp on stock internals. RS is ball bearing turbine which has very good reaction on low rpms. Any ideas?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Aug 08 2008
    2017 Q5
    Houston, TX
    Re: Garret RS turbo kit for 2.0 TFSI
    bump for information?
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    it's prob the same awe kit that another thread is about. unless he really means diller and it runs on pickle juice
    Senior Member Two Rings UrKurt's Avatar
    Sep 01 2007
    1990 325is, 2008 A4 2.0t
    California
    Typical RS turbo upgrades (like VF engineering's) require built internals (you'll need stronger rods) for higher power levels, so this sounds right.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Here in Greece, multiple TFSIs, such as GTIs, S3s run over 360hp with stock internals, for a very long time...So I dont think its a problem up to 400hp...
    What im saying is not something new though...
    Jun 05 2007
    Phillips Ranch, CA
    Quote Originally Posted by UrKurt View Post
    The RSS turbo upgrade from VF Engineering does not require built internals and will achieve 320~350whp. Only the RSR will require built internals and will give atleast 400whp.
    I dont know if you guys saw this it was in the TT forum, This was an event in Greece from one of VF Engineerings new vendors
    Quote Originally Posted by Delius@VF View Post
    Our new distributor from Athens Greece RAS has sent us these pictures from the Athens Tuning Show. I thought you TT owners would be interested?
    Nice display of our RSS kit
    For more details please visit our web site:
    http://vf-engineering.com/images/choosebrand-turbo.gif
    The cars and candy.
    The ever demonic grin of the TT!
    Our kit also fits the SEAT Cupra. Note the Greek flag on the engine cover.
    Thanks for the pics RAS
    Sep 01 2007
    California
    Sorry for the confusion, I realize I wasn't very clear. When I said "higher power levels" I mean within VF's range of kits, i.e., the RSR.
    Jun 02 2008
    Greece
    Yeap they are from Greece...Actually i know one of the guys in the photos above...LoL
    Sep 15 2008
    Ukraine, Kiev
    IT IS not RS turbo kit from VF(I'm not against that fellows, but my car is on the other continent...).
    Quote Originally Posted by acidrome View Post
    400 hp is possible on stock internals! But for how long? It would be a time bomb!
    This kit is build on Garret RS turbo VF BT kit is build on 2871R which has more potential than RS turbo, but it has slower response because of larger turbo wheels. I need Very smooth power in car from low rpms, and not to have the beast at 5000 rpms
    320-350 hp is much more than stock and this would be enough not to hurt internals
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: Turbo kit based on Garret GT2860RS for 2.0 TFSI
    S3s kind a have a thing called FORGED INTERNALS.
    Ps, Stock rods can gold up to 400 HP
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by HID View Post
    If rods could gold up to 400, this amount of ponies will find weak place in engine, to take the way out. It's like when you ride on a time bomb
    With forged internals it is possible to have 600,
    but you have to rebuild your engine significantly, I'm not talking about sum of money required
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by DOBERMAN@UA View Post
    Exiting, inst it ?
    I would have a high boost and low boost tune, High boost as close as I can get it to 385 and low 360 ( BHP ). Maybe I would throw in race to get that extra few ponies. ( wouldn't go anything smaller than a GT30 )
    Remember this BTs dont produce that much TQ
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    Exiting, inst it ?
    I would have a high boost and low boost tune, High boost as close as I can get it to 385 and low 360 ( BHP ). Maybe I would trow in race to get that extra few ponies.
    What turbo do you have?
    Oct 14 2006
    MK6 Jetta
    South,FL
    Almost forgot to say, many 1.8T guys do what I just said on GT 28s and 30s, most motors last for a couple of years, but when they go, they go.
    Last one I saw had one of the rods snap and make a hole the size of my fist on the block, plus the piston welded itself on the cylinder wall, and the rod produced other less pronounced craters.
    K03S, and an unhealthy amount of nitrous.
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    That's what I'm talking about, I don't wanna to buy new engine in one year.
    For more power you should pay more atentions to internals
    Oct 14 2006
    MK6 Jetta
    South,FL
    By all means, do internals, because once you get a taste of the new power you are going to want more, and catastrophic failure is not nice.
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    On stock internals I'm going to have 320 hp. What do you think is it critical for engine?
    Oct 14 2006
    MK6 Jetta
    South,FL
    That is fine, just make sure you have your fueling right.
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    APR fuel pump and s3 injectors
    Oct 14 2006
    MK6 Jetta
    South,FL
    Great, good luck
    Just double check on the injectors, I think there are BT specific Injectors.
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    Talking about garret RS, is it really so good as I was told?
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    the 28rs is good for small power, and decent low end torque. if you're looking for 320chp then a 28rs is fine for you. and no, you don't need to do rods for that power. the rods in these engines are stronger than 1.8ts
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by AAAA View Post
    What is the critical amount of hp for engine?
    Oct 14 2006
    MK6 Jetta
    South,FL
    400 bhp
    -EI AL CAI.
    -Driver Mod.
    Sep 15 2008
    Ukraine, Kiev
    400 bhp
    Maibe I could consider about 350 or it mo risonable to stay with 320?
