Results 1 to 7 of 7
    Veteran Member Three Rings B5in's Avatar
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    APR couldn't flash my ECU :( please help
    Waaaaaaaaaaaaaaaaaa
    Well I took my 2001 Allroad in to get the 93oct. program flash & they said my ECU wouldn't allow them to flash it. They said they tried 3 different ways & no worky
    They said the only reason they can think of is the previous owner must have had it chipped before, but sottered, but tdoes that mean my car is chipped already, it doesn't feel like it.
    Do you guys have any other ideas as to why it won't let them flash my ECU
    Nov 19 2005
    Pair of (. )( .)
    Re: APR couldn't flash my ECU :( please help
    just get another used ECU and chip it ;)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Sep 20 2008
    Woodinville, WA
    Try and have them flash it while trickle charging ur battery. There's a voltage threshhold (which I don't know the exact value of) that is within acceptable range for normal car function, but is too low to allow ecu flashing.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    they can't bench flash the ecu?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    open up the ECU and check if you have a socket on it already, might be a encryption socket. Did they try to flash it on the bench or thru OBD?
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    They said they tried it 3 different ways, but all through the OBD, looks like I'll have to crack it open, I was just scared to open up such a fragile thing like that, sometimes you just gotta sat..."Fukk It"
    Nov 20 2005
    it's not that fragile, you'll be ok
    is it 4:20 yet?
