Results 1 to 23 of 23
    Dec 01 2007
    Orange County, NY 10918
    Stage 2 Southbend?
    I just put a southbend stage 2 clutch in my 2003 A4 Avant. Modds are in my sig. Been waiting on this whole breakin period. So this week i was well over 1,000miles, and got on it today and nothing. Clutch is slipping, why is this happening.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Stage 2 Southbend?
    It is slipping because you most likely didn't break it in correct seeing that a SB stage 2 has kevlar on the disk and it needs to be heated up to set. 1000 miles doesn't mean much if you never really used the clutch which is why they recommend 500 stop/go traffic. Last time I had a kevlar clutch setup I was able to break it in 50 miles and did that by doing short low rpm 5th gear fwy pulls to heat the kevlar up and let it cool.
    Dec 01 2007
    I do stop and go traffic. I commute to NYC everday. I was fine all week till today. Was pulling hard and holding.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jul 07 2004
    socal
    Well if it was holding full power before and now it wont you most likely glazed the disk.
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    How do you know when it's broken in? And then the other day, I got up to like 14psi (oops!) and it slipped a little... is that bad?
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Dec 01 2007
    Quote Originally Posted by GTRS A4 View Post
    Exactly how do you know if its broken in. Talked to AWE and they said it would have to be sent out to see whats wrong with it. There word against mine, I guess. But they were cool about it to me.
    Guy drove it today and said it was fine. Then i asked him what RPM he got it up to and said 500rpm, and it shifted all gears and held. Told him he needs to get it up to atleast 3,000-5,000 rpm for full boost to kick in. He waslooking at me confused. I saidon highway at 80mph, the car runs at 3,800 rpms. and when i get on it to pass it's not holding.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jul 11 2008
    Illinois
    Anyone? I don't want to mess up this clutch
    Anthony
    Dec 01 2007
    Got car back from the guy that did the install. He said it was fine. The car was fine. Driving just like i always do. Then all of a sudden it starts up again. Is there something wrong with tranny then. Guess when it heats up it startsto slip. What the F*ck?
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jul 07 2004
    socal
    You might want to contact the shop you bought it from or call up Southbend. This is one of the reason I dont suggest the stage 2 to my customers because it does use kevlar.
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Interesting, I've been looking at South Bend, but stage 2 is lowest I can go as I'm making close to 300lbs already. Who else would be recommended?
    Jul 11 2008
    Illinois
    Go Stage 4 South Bend!
    Anthony
    Aug 14 2007
    Ottawa, ON, CA
    Why does the stage 4 not have Kevlar on it?
    Dec 01 2007
    yeah whats a good clutch setup that doesnt have kevlar in it. This is costing way too much money.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jul 07 2004
    socal
    Quote Originally Posted by Casius View Post
    Because it uses a medium metal on one side and organic on the other, that combo will hold more power. That same disk is used for the stage 3 for the lwfw with the HD pressure plate that has less clamping pressure vs the SS that comes with the stage 4.
    Jul 11 2008
    Illinois
    I bought my clutch from ^him! GREAT guy! He definitely knows his stuff too!
    Anthony
    Buncha motorcycles
    Memphis, TN
    its slipping because you didnt get a strong enough clutch for that vicious torque spike the k04 has. you should have gone stage four (OFE SS) or stage 5 FE SS
    APR Stage 2/AWE Intake
    Jan 16 2007
    Wetzlar
    f Southbend and their junk. I just got Sachs Racing kit. I did not install it yet- sometimes next year.
    Dec 01 2007
    spoke with a tech at southbend this morning. He said " if i used the oem flywheel, and they didn't resurface is it could wear on the kevlar. as a result when it heats up it will slip till the two match up to each other" I asked do i need a new one and he said "NO" just have to wait right now i have 50% clutch till the two work out. So i guess i'll wait and see how it goes. Better be fixed before the Cliffs of Insanity!
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Ahh damn that sucks, does anybody know what is the purpose of resurfacing the flywheel ? I'm probably ordering my new SB stage 1 clutch in the next week or so, and idk if I will need to resurface the stock flywheel or not. I hope I dont have to, cuz it'll probably be a PITA to get it done.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Jul 07 2004
    socal
    Quote Originally Posted by A4 KiDD 810 View Post
    To remove any high spots so you end up with a pefectly flat surface.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    You are my hero. I will never drive my car in NYC. Going to a wake in the bronx tonight, taking the tahoe down.
    Dec 01 2007
    Quote Originally Posted by gq9 View Post
    Oh come one it's not that bad. I drive the car the way it is onto construction sites too.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    So the difference between stage 3 and 4 is the SS vs HD pressure plate? Mike can you or anyone else knowledgeable elaborate more?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
