Results 1 to 7 of 7
    Established Member Two Rings stilldubbin203's Avatar
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    Thinkin about buying a 1990 audi 90...need help!
    ok so i found an older lady selling a 1990 audi 90. it has 224k all highway miles and the paint is faded red but the body is immaculate along with the interior. Heres what i noticed is wrong with it: The battery was stone dead, hooked up jumpers and still nothing, then i wiggled the positive cable and it threw some sparks then started, possibly a short it bad connection? The next is the brake pedal is rock solid and you have to press it real hard to even get a little bit of brake. The abs light is on and the fluid resovoir is filled to the top and the fluid is black. Possibly bad fluid/too much? When you shift the rear end makes a loud clunk, checked underneath and noticed some fluid on the rear end. Bad seal? also i dont think the power steering works, actually do they even have it? But anyway its really hard to turn. so those are the main problems that i noticed, oh and also theres a loud hissing coming from near the back driver wheel, i figured it was the fuel pump, is this normal? Any help would be great. BTW the lady only wants 300 for the thing so i cant really go wrong im just wanna get an idea of what im in for.
    SoCo Dubs Bitch!
    99.5 A4 1.8TQM - / GT2871r elim. \ / Tapp Tuned \ /ATP High Flow Turbo Manifold \ / FMIC \ / siemens 630cc \ ATP Hard TIP \ Coolingmist/Labonte Meth injection \ Fprd Lightning Maf \ / stasis coilovers \ /StopTech Rotors + Hawk Pads \ / tyrolsport afpr \ / borla catback \ / DIY intake \ / clear corner mod \ / 8000k hid's \ / vdo center vent boost gauge \ / s4 bumper with shaved center grills \ / aem wideband \ / 18" RPM 505 Wheels \ / Forge 007\ /Turbo XS MBC \
    Veteran Member Four Rings snopyro's Avatar
    '08 TT 3.2q Roadster (for sale), '20 A7, DC Taco, SV650s, lots of snowboards
    Re: Thinkin about buying a 1990 audi 90...need help!
    I have that same brake feeling on my 1991 Coupe Quattro. Seems like I have no brake assist, but I had the 'bomb' replaced, so I know I have something there. You might want to check out: www.20v.org for common ailments to these vintage cars.
    Registered Member Two Rings Shvltme_90 q's Avatar
    Aug 20 2007
    1990 audi 90 q, 94 mustang GT
    Post Falls ID
    the brake issue is the assist. not vacuum on those cars.... i cant remember, basically a little valve that holds some pressure. the only thing that is easy that i know you can do is to flush the power steering system. (sounds weird but it is not a vacuum assist) yep. that is your brake issue. i am thinking of just ditching the assists all together.
    034 has a system to swap over to the more simple vacuum assist system.
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    if its a 20v, it worth putting effort into it.
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Buy it...for 300 dollars even if you cant drive it, you can part it out and make back atleast your 300 dollars if not more.
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Do it.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Veteran Member Three Rings marcus1701's Avatar
    Jan 06 2007
    a6,tt,99taurus,forester
    orinda, CA Hong Kong
    lol you think she'll sell for $300?? More like $1000 if she knows what they're worth.
    02 Silver Audi TT 225Q Roadster - Stg 2 APR Chip, "BMW blue" tint, S-Line F & R, APR 2.5" Cat-back exhaust, APR Slcn Hoses, ECS Undrve pulleys, APR FMIC -Sold to a friend
    06 Alpine White BMW Z4 3.0SI Prem. Pkg, Nav, Steptronic, 19" HRE 847R 19x8.5 19.x10
    97 Honda Accord DX Auto, hubcaps
    08 White Forester 2.5X Premium Pkg - leased
    03 Mineral Grey Ford ZX2- Given to a friend
