Results 1 to 6 of 6
    Established Member Two Rings 01b5a4qms's Avatar
    Sep 17 2008
    01 B5 S4, 2005 f250 6.0L PS
    Pocatello Idaho
    so i was wondering...
    right now i'm sitting in my lab class... (i don't know why that is important at all), but i started thinking of ecu stuff. lately i have really been wanting to look into the haltec interceptor. which is a piggy-back ecu system that lets you control boost, fuel, and timing. it runs around $800ish. about 2 months ago i talked to a guy on audiworld that succesfully put that system on his 97 aeb. i asked him for the schematic for reference to see what i would need to do to put it on my car. but then again i'm not sure if the ecu wiring is anywhere near the same for aeb to the awm. so really what i'm getting down to is, should i take the path less travled and go haltec, go the flow and just do giac, or do you guys know of a better piggyback or stand alone system that is should look into.
    this is just kinda a boredom question on an idea i've been flirting with, but any personal imput is more than welcome. negative or possitve. just tell me what you think. thank you.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: so i was wondering...
    what level of aggravation are you willing to put up with?
    Sep 17 2008
    Pocatello Idaho
    agression that will rip my nuts to my chin... haha! no i'm looking into running a gt2876 or maybe 3071r... i want to run around 20-25psi, and have around 350 400 wheel. then it's just hoping that the tranny will hold that. i think that should settle my boost crave for some while, or not...
    Oct 29 2005
    10speed
    San Francisco, CA
    I talked to Haltech, they said it works on the GTI and would work on the A4, but Ive heard conflicting things about how itll make the ECU flip out on you, things wont work, etc etc
    who knows if its true
    - Clint
    Nov 21 2006
    san francisco, ca
    It works fine on my AEB. In order to to make things easier you could send off your ECU for a couple tweaks and get rid of maf cut and while your at it raise the rev limit.
    But currently I am running it with a stock 557p and got around the maf cut with controlling the fuel pressure manually and a bit of scaling changes to the maf signal. I have a couple maps, one for 110 leaded and 1 for 93 that could give a good base tune to start from. It took a ton of pulls to get it right, like 76 IIRC but again no one had done it before as far as i know.
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'd go with a known successful tuning company. Skip the Piggy back, it's not needed for either one of those turbos, or your desired power level. GIAC doesn't make a file (without a custom tune) that will make that power. Their file is for a 28RS or 2871, no 30xx framed turbos.
    350-400whp can be done on the stock ECU, no need to go piggyback. Unitronic, Eurodyne, C-Tapp, etc can utilize the stock ECU. I'm sure there's a couple companies I'm forgetting.
