Results 1 to 9 of 9
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Major Maintenance, Tips, DIYs etc?
    So my 01 has 100K on the clock now, and a sqeaky serpantine belt and a loeaking power steering pump.
    So I have bought new serpentine belt, AC belt, t-belt, tensioner, water pump, power steering pump, a Chilton Guide and some nice Axxis front pads. Any one have a good walk through or DIY on the T-belt and removing my S4 bumper?
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    Re: Major Maintenance, Tips, DIYs etc?
    this one on audiworld is probably the best out there:
    http://www.audiworld.com/tech/eng35.shtml
    i printed it out and followed the steps. if youd like i can look into uploading all the pics i took. i tried to take a pic every time i removed a screw so id know where everything went back.
    edit: here i uploaded a bunch of pics. note that in the middle there i did the cam seals which you probably wont be doing.
    http://picasaweb.google.com/bicball/Timingbelt02
    i'd recommend being very organized, i lined up every screw/bolt i took off in a line on the curb so i could put everything back on in the same order they came off:
    Active Member Two Rings 01Audi1.8T's Avatar
    Apr 08 2008
    2011 Toyota RAV4 Sport
    New Freedom, PA
    Just looked at this how-to. It's very thorough but where the hell is the other cam gear?
    Mar 29 2007
    Is the street.
    what? are you asking why theres only one cam sprocket? it's because our cams are attached by a chain. the exhaust cam is spun by the timing belt and the intake cam is spun by the attached chain. you can see the chain on the left here:
    Jan 04 2005
    530, California
    So is the still an interference type motor? i.e. t-belt goes so do valves.
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
    Mar 29 2007
    Is the street.
    yes
    Apr 08 2008
    New Freedom, PA
    Quote Originally Posted by Bic-Ball View Post
    That was my question. I've never seen anything like that before. Always two cam gears.
    Mar 29 2007
    Is the street.
    im pretty sure it's done what way because the car controls timing through that chain by delaying or advancing the intake cam.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 01Audi1.8T View Post
    its a stupid design but whatevs
    - Clint
