Results 1 to 11 of 11
    Senior Member Two Rings 4R!NGS's Avatar
    May 11 2008
    Nassau, Bahamas
    HID kit problems?
    I have the halogen headlights in my b7 and i was wondering if i install a hid kit will that trip the computer or cause any thing to go wrong?
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    Re: HID kit problems?
    WE ARE SPARTAAAA let the flaming begin!!!!!!!!!!!!!!!!!!!!!!!!! hope you have like 2k dollars because everyone will say get oem projectors but i have HID'S on halos and in fogs ,they dont blind people they look good all you need is a resistor and you won't throw a code
    Apr 18 2008
    Jacksonville, FL
    ok, with *proper* punctuation use, here's the deal. in answer to your question, assuming you do it right (see lower) you will need to tell the computer (with a VAG-COM cable) that you have installed Xenons.
    "Doing it right" involves getting proper xenon housings. again, check the FAQ as i'm pretty sure there's a DIY link for the swap. if you don't put in proper xenon housings and just stick the xenon bulbs in your current halogen housings, you will cause glare somethin' fierce. the reflectors you currently have are designed around the characteristics of halogen bulbs. xenons are different enough that the reflector won't do the proper job of cutting the low-beam light pattern so as to not blind oncoming drivers.
    can this information be added to the FAQ? i've answered this question too many times in the past couple months.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jul 31 2007
    Tampa,Fl
    i will translate the above with bad punctuation you will need 2k dollars if not i will not be oem ,with halos and hid's you will blind people ,i bet 99.9 percent of people that say this have not seen this set up in an a4 with a good set of HID'S ,so basically the SPARTA ATTACK has started hahahaha
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    if you absolutely had to put the kit in the halogen housings, just make sure the arc of the hid bulb(part of bulb that emits light) is at the same distance from the base of the bulb as the h7 halogen bulb, in other words, make sure both light emitting parts of the bulbs rest in the same place in the headlight. Reason being...the halogen reflector is designed around the bulb being in a certain spot, if this spot is changed (bulb too in or not in enough) the beam pattern will be completely different, most people who buy kits dont know this and they just throw the bulbs in, and where the beam used to cut off, its now scattered everywhere. To ensure your kit bulbs are the same, just make sure the arc on the hid bulb is in the same place as the little spring filament in the halogen bulb, you can space the hid bulb with rubber o-rings if this isnt the case, after proper installation, ENSURE that you aim the lights! before doing anything..
    park your car 10 ft from a wall..
    notw turn on your halogen lights and mark the wall where the beam is..
    now properly install the new kit...
    re-aim lights to where beam is about 2 in. lower than halogen beam..
    congrats! you now have a non glaring hid kit in a halogen housing!
    ohh and dont buy anything other than 4300k or 4500k bulbs or i will find you and make you drink oil!! well 6000k is fine too but significant loss of output compared..
    haha have fun hope i helped
    Jul 31 2007
    Tampa,Fl
    plus i guess get a good kit mine has like a metal shield on one side of the bulb i guess to have the light pointing down
    Aug 08 2008
    2017 Q5
    Houston, TX
    go oem and get the whole thing done and spen $$$$$. haha. word. i think i'm sticking with those xenon match bulbs until my next ride that will have xenon stock. word
    Veteran Member Three Rings darin1274's Avatar
    Dec 28 2007
    2016 VW Passat TSI
    Phx, AZ
    where is the headlight adjustment screw on the non-HID headlights?
    ...step your shoe game up!
    2007 VW Passat Variant-Alpine Gray- 19" RS6's, Euro Turn Signal, HID's, VAG Mods, Neuspeed A3 springs, Dewipered
    2007 A3-Silver
    Apr 07 2008
    Quote Originally Posted by darin1274 View Post
    same place as the xenons....on top (white screws)
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    I got mine, and i didnt spend 2k. Get them here from lowesta4 and do the installation yourself.
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Quote Originally Posted by praudi View Post
    Nice. What brand was this?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
