Results 1 to 32 of 32
    Senior Member Two Rings dobos100's Avatar
    Dec 13 2007
    los angeles
    Just got K04'd and have some questions.
    Little back story on the car: its a 5.5 A4 Quattro, TestPipe, APR Chip, full britalman exhaust, power was good, especially on the top end, overall a nice improvement over stock. This was my setup before going with the K04 hybrid.
    Few days ago i had the K04 installed and a highflow cat put in (coudn't deal w/ the loudness of TP) along with the updated software. The car seems to have more torque but I barely notice a difference. I remember when I went thru the same with my B5 1.8T and the difference was significant.
    So what I would like to know is has anyone else had this experience, or something is wrong and should do some investigation.
    I'd hate to think I spent all this money for what feels like 10-15hp gain.
    Thanks
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Re: Just got K04'd and have some questions.
    which kit did you go with? Who did the tuning and did you do anything else with the turbo install, fuel injectors, fuel pump?
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    This is definitely something you shoudl discuss with the shop that did the work for you. I'm sure it wasn't cheap and they want you to be happy with it so they should be very helpful. Plus, they know the specifics of your car way better than anybody on here.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    I think you need to get a fuel pump as well. That'll certainly help you notice a major difference.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jan 01 2008
    Long Island NY
    what ko4 kit did u buy
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I'm guessing you got the APR one?
    Dec 13 2007
    los angeles
    Quote Originally Posted by extremesport3 View Post
    I just did the software (APR) and KO4 (upgraded my K03 intersnals), no injectors or pump. I rather not say who did it just yet (great people, good service), I am not blaming them at all, will be going back to the shop saturday to try a few different settings. Until then I just wanted to see if this is normal without the additional upgrades, or I should look for a problem.
    Dec 13 2007
    los angeles
    Quote Originally Posted by Auditude2.0T View Post
    APR software, upgraded my K03 internals to K04
    Jan 01 2008
    Long Island NY
    How much? You need fuel pump, injectors, and apr software is made for k03 not k04 that's why the gains are minimal
    Dec 13 2007
    los angeles
    I paid under 2k for the Turbo Retrofit, HighFlow Cat, installation, and flash to KO4 software.
    Nov 12 2007
    Grand Junction, CO
    Doesnt that kit cost like 5g's?
    Apr 14 2008
    Oceanside, New York
    it seems like a patch and match way to do it but as long as it works thats great. I would say you should have waited on the new K04 kit to come out and you would have gotten all the other stuff - fuel pump, injectors, intercooler etc.... Good luck!
    Dyno the car to see if you have decent numbers! Keep us posted.
    John
    BMW M3 ZCP
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    I think he's saying he put an upgraded compressor wheel in his k03
    -Kris
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    yea i think they just swapped out one of the sides of the k03 with ko4
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Dec 13 2007
    los angeles
    Quote Originally Posted by vtracer20 View Post
    That's correct!
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Quote Originally Posted by dobos100 View Post
    That's correct!
    Someone correct me if I'm wrong here, but that would mean you don't have a true K04. I know the K04 is a bigger turbo, not by much, but still.
    I would definitely take it back to the shop and it might be because the turbo itself is still the same size...?
    Apr 14 2008
    Oceanside, New York
    actually the housings are exactly the same, the only difference is the compressor wheel. The blades on a K04 are large surface area, its not all that much bigger of a turbo.
    BMW M3 ZCP
    Mar 03 2008
    Washington
    Thanks for the clarification...I'm always learning new things here.
    Nov 12 2007
    Grand Junction, CO
    I'm very confused.
    Mar 03 2008
    Washington
    Quote Originally Posted by AudiWxGuy View Post
    I'm very confused.
    I actually am now, too. After further research it seems that the K04 is actually very different from the K03. Granted there are tons of different models of each.
    From what I've found it seems as though the K04 is definitely not a direct bolt on. Which is at least partly due to the fact the DV is attached to the K03 while the DV is separate from the K04 and that other pipes/flanges just aren't the same.
    The pictures out there make it look like the K04 is actually a bigger housing as well...not by much though.
    Apr 14 2008
    Oceanside, New York
    well i have the K04, and i have seen them back to back and they look incredibly similar. I may be mistaken though.
    BMW M3 ZCP
    Jan 10 2007
    VA
    The K03 and K04 use the same housing. The K04 has a different compressor wheel for improved flow. The turbo's themselves are the same size. There are different variants of the K04 turbo for different applications, A4, TT, S4 ect.
    A K04 is a very minor upgrade compared to a GTRS or similar BT.
    Without appropriate fueling and tuning, a K04 upgrade does very little for performance.
    Mar 03 2008
    Washington
    Just found this link: http://www.passatworld.com/forums/sh...d.php?t=214079 seems to confirm what you stated extreme.
    Dec 13 2007
    los angeles
    Without appropriate fueling and tuning, a K04 upgrade does very little for performance.[/QUOTE]
    So basically i need to buy a FSI HP fuel pump and injectors in order to have gains I can actually notice?
    Anyone wants to get rid of their APR FSI fuel pump??
    Jan 10 2007
    VA
    APR's FSI High Pressure Fuel Pump, S3 fuel injectors, and K04 software for an optimized K04 setup.
    Apr 14 2008
    Oceanside, New York
    i have all the associated mods and im running 275 wheel hp and 318 wtq. I think thats pretty good, its not GTRS territory but enough for a daily driver.
    BMW M3 ZCP
    Jul 21 2004
    South Florida
    If the dyno below is your dyno then you actually dynod 274 CRANK hp and 318 Crank torque. The MAHA dyno as you can see lists the "pWheel" wheel horsepower and also calculates the "pEngine" or crank hp and also the "p corrected" the corrected hp at the crank given the ambients. The wheel hp was listed as 195whp.
    2018 Audi S5
    Gone-
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    its the software. i have the pump (this particular k04 doesn't require injectors, the s3 variant does). that's why apr took it off the market and is trying to release the s3 version instead, with injectors for this one.
    Dec 13 2007
    los angeles
    Quote Originally Posted by AAAA View Post
    That explains things, I wish I would have known...
    Jul 21 2004
    South Florida
    Rather it's the turbo. That variant of the K04 is smaller than the S3 variant you are talking about and much more limited as far as power output. That's why the S3 variant needs or benefits from injectors. cheers! Mike
    2018 Audi S5
    Gone-
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Quote Originally Posted by bhvrdr View Post
    yes, but the software was a big problem and they couldn't figure it out. yes, the s3 is bigger, hence the higher hp numbers and the need for injectors
    Jul 21 2004
    South Florida
    guess it was on cars that weren't quattro 6mt because i was holding 4 more psi at redline with my k04 kit than the k03 could and not a hiccup. I agree I wanted more power but I did back to back datalogs on the chipped k03 and their k04 and there was more air going in and more boost. the software seemed spot on. the requested and actual was better than i've seen in a bunch of programs out there that had been out for a couple years. i couldnt find a problem with the programming at all. it was a turbo limitation.
    2018 Audi S5
    Gone-
