Results 1 to 15 of 15
    Mar 22 2007
    Long Island
    turbo/clutch job and car goes into gear but doesnt move?
    just did a turbo/clutch job on an s4 and the car doesnt move. pretty positive i didn't fk anythin up.. but who knows. if i put the car into any gear, release the clutch, the car just sits there and doesnt move, but rpm rise. speedo doesnt. seems like the clutch is just slipping. all axles r connected and tight... and if i broke a cv re-installing the axles i think id hear it when it was trying to move, no? suggestions? thx
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: turbo/clutch job and car goes into gear but doesnt move?
    if the car is not moving at all and the engine is running, my guess if you did not install/align the shifter correctly.
    Can you shift into 1st and reverse with out any problems? just gear wise, can you push down and get into reverse?
    if u broke a cv joint, u would definitely hear that.
    Mar 22 2007
    Long Island
    yes i can shift into every gear no problem, i can also hear them selecting in the tranny
    May 22 2008
    St Clair Shores, MI
    Can you hear/feel any difference when you push the clutch pedal in? Have you tried shifting without pushing the clutch in?
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Mar 22 2007
    Long Island
    no differences when i put the pedal in or out.. also just installed a new slave and bled the system fully. shifts fine without pushing in clutch, car off of course..
    Apr 27 2008
    silver s4
    LI
    input shaft?
    i would try and see if u can turn the drive shaft by hand and hear the gears move in the tranny. unless you didnt tighten down the bolts to the fly wheel or something and its just spinning.
    You have to retrace your steps when you reinstalled everything. think about every step and write it down.
    Mar 22 2007
    Long Island
    ya i guess i will put the car in the air and see what it does in gear and running.. i torqued all the flywheel bolts to specs. this sux!
    Oct 29 2005
    10speed
    San Francisco, CA
    hmmmm, this doesn't sound good... You put in the new throw out bearing right? and the slave cylinder is in there right?
    - Clint
    Mar 22 2007
    Long Island
    ya throwout is in right, brand new slave is in right.. i can hear it pushing the pressure plate normally
    Oct 29 2005
    10speed
    San Francisco, CA
    editd
    - Clint
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    What about when the car is on can you put it in the gear without pushing the clutch? If yes than the pressure plate is not on the clutch, either the clutch spun or it's not installed right. I have seen it installed backwards in a different car but i dont think this is possible on an S4.. Look around maybe you forgot to install the throwout bearing lol
    I was helping a friend install a stage 2 clutch on his B7 and it did the same thing. After taking out the tranny we found out that he received a wrong clutch disk and had so get a new one, everything was fine after we got a replacement in. Just a thought.
    Mar 22 2007
    Long Island
    it def seems like a pressure plate issue to me.. not clamping hard enough is what it feels like to me. guess im droppin the tranny lol
    Dec 06 2007
    Calgary, AB, Canada
    Which clutch/PP/FW did you use?
    Mar 22 2007
    Long Island
    oem flywheel, rs4 disc/pp.. i used the tranny bolts to pull the tranny to the block. i think the input shaft didnt seat properly, gonna drop the tranny this weekend
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Quote Originally Posted by S4444 View Post
    what ever happened of this??
