    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    No power to driverside tailight ? any idea ?
    So a while back someone broke my passenger side taillight and left a big hole on it, I replaced with a new taillight the other week, but I still had a taillight out ..the dealer checked it and said there is no power to the taillight
    the panel where you but all the bulbs is all black or burned-out, so im thinking when the taillight had the hole, water must of gone inside and fried the panel ?
    or maybe Its a fuse ?
    Any suggestions ?? Thanks
    01' B5 S4 STG.II TIP
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Re: No power to driverside tailight ? any idea ?
    BUMP
    Senior Member Three Rings rcjustin's Avatar
    Aug 29 2007
    00 s4
    doublechekc for power urself. i had a problem with the bulb socket. Th metal tabs at the bottom simply bent too far in and stopped contacting the bulb. I just used a small pick and bent the tabs back to original position and had 0 problems ever since. worth a shot.
    Silver SSP Stage 3+ S4
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    thanks
    Aug 29 2007
    00 s4
    was that the problem?
