Results 1 to 11 of 11
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Possible to change amount of "blinks" for the komfort blinker?
    Google searched the topic because I heard it was possible, after searching here on AZ I didn't find anything referring to this, nor did I find it on the ross-tech website. This is a link I found from Google posted at AudiForums, quoted text below is what was said.
    To change the number of times the blinker flashes when you tap the turn signal stalk, go to Address 09, Central Electronics. Select function 10, Adaptation. In the Adaption window, go to Channel 02. Note the stored value (original is 3). Set the new value to the number of flashes you want, and then test the output. If the test gives you the desired output, key SAVE, then DONE.
    Can anyone confirm or deny this? If so, what vehicles did it work on?
    I am going to try it tonight when I get home from work and post if it works or not...
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Re: Possible to change amount of "blinks" for the komfort blinker?
    i've been wanting to increase it to 5 ever since i got the Avant but was led to believe it was not possible to change the value at all... let us know if you get it to work... although the info you posted is for a Touareg, and like i was saying i doubt it can be modified on the B6s...
    MY2022 B9 Q5 55 TFSIe: Daytona Gray||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    i want 5 too. 3 just isn't enough for me
    Dec 05 2006
    So. Cal.
    Meeeee Tooooo wants de 5.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    I just want 4. Can I please just have 4? Thanks.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Senior Member Three Rings iluvTTs's Avatar
    Oct 23 2007
    You may have 3 and a half. Max.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    According to the Ross-Tech wiki address 09, channel 02 sets the brake light dimming value on a B7 http://wiki.ross-tech.com/index.php/...onics_(8EC/8ED)
    Oct 19 2005
    Virginia
    Quote Originally Posted by PetrolDave View Post
    correct sir, i messed around with VAG for about 2 hours last night searching through just about every adaptation/coding channel and couldn't find anything... which is surprising considering the amount of other things you can change with VAG... i'll keep searching around for it and see if anyone else has actually changed it as well...
    sorry for the crappy news fellas
    -Cliff
    Current:
    im happy with 3 :)
    Registered Member Two Rings ososlow's Avatar
    Oct 22 2007
    LA
    Quote Originally Posted by iluvTTs View Post
    does it mean it'll stay ON after 3 blinks?
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    I want 3 1/2 binks before I push the other car out of the left lane. They must respect my "authoritie".
