Results 1 to 4 of 4
Thread: Boost Problems
    Established Member Two Rings Plow Jockey's Avatar
    Jan 06 2008
    99.5 A4 1.8T, 97 A4 1.8T
    Parker, Colorado
    Boost Problems
    Hey guys, driving around my brothers 00 chipped S4 and having some boost problems. The car will pull really hard then dive on it's face (still at WOT). It will sometimes boost to 20psi then drops down to 10psi then holds at 5psi (all at WOT). Then other times it will boost to 15psi and hold at 10 or 11psi(WOT). Other time it goes to 15psi then holds at 5psi. He doesnt remeber what chip it has, it has brand new dv on it(dont know what brand). I just want to fix it cause that thing pulls hard and would be alot of fun to drive. any ideas would be helpful. Thanks in advance.
    Plow Jockey = A person who plows a field behind a horse
    Veteran Member Four Rings 2380S4's Avatar
    Jul 16 2008
    2001 S4 Avant, 07 DTM S4, 15 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    Re: Boost Problems
    TBB, blown hose, DV's maybe not sealed could be a waste gate as well. Boost leak some where....
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Boost Problems
    Pressure test the car first to make sure there are not leaks. If that turns up nothing it may be your N75
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jan 06 2008
    Parker, Colorado
    Re: Boost Problems
    thanks will do
