The absolute key is going to be for you to work on your launch. Once you get your 60ft times down in the 1.8x second range you'll get a good time. Dont be afraid to run the car out to redline as well. There is no problem running past the power peak to the redline since you want to use as MUCH as possible of the lower gears in this car as possible (ie, it's better to use 100% of 2nd gear and overshoot the power peak because 2nd gear will have more power due to gearing then 3rd gear will have). Bottom line is to get the launch right. If you get a 2.2x 60 ft time (it, crappy crappy launch) expect to see high 14s. If you get a 1.7x 60ft time, expect to see mid to upper high 13s. It will make the difference. I'd also recommend inflating the tires to 50++psi. You will need a tiny bit of wheel spin so you dont bog and if you're only going to launch at 3200rpm then you'll need all the help you can get. I'd overinflate the piss out of them.
PS, goodluck and post your timeslip when you get back. I'll add it to the database.
cheers! mike
