Hey guys, i was just driving to the supermarket and on the way out of the parking lot, i stop at a stop sign and go into first and then proceed to let the clutch up since its my turn and the pedal comes up really easy. i really lugged the engine, also since it was a on a slight hill. But mainly i wasnt expecting the clutch to come up so easily. The pedal is softer than usual to push down and for it to come up. Also when i got home and did a problem shooting drive around the block, some times i heard a sound after i let the clutch out and was moving in gear. just after engagement and as your letting the clutch to the top. It was a thunck, and somethign like a heavy click. I also had to bring the pedal up after engagement one time. It didnt come all the way up.
I checked the brake fluid and that is full. Im 99% sure that the slave uses the brake fluid and that there is no separate reservoir for it. Other than the clunk sound and mushy pedal it works fine. all gears go in smooth and no grinding.
any ideas guys??
