Results 1 to 9 of 9
Thread: DTM Grill
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    DTM Grill
    Is the DTM grill that is in the S4 25th edition the same size as the regular A4?
    The usual things!!
    Resistor Install
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Re: DTM Grill
    yup
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    DUH! an Audi
    los angeles, CA
    Re: DTM Grill
    x2
    Feb 16 2008
    Oakdale, MN
    Re: DTM Grill
    Sweet, that will save me some $$$ I'm thinking about the dtm front bumper! Do you think ill be able to make a bracket for my fogs? Or should I try and do the s6 led's?
    The usual things!!
    Resistor Install
    Veteran Member Four Rings gods_kitchen's Avatar
    Re: DTM Grill
    The S6 LED won't fit unless you do some serious cutting on the DTM front, 1sicknickel has tried it but no luck.
    Feb 16 2008
    Oakdale, MN
    Re: DTM Grill
    Ok. So can do you think I can make a bracket for my current fogs and use them in the bumper?
    The usual things!!
    Resistor Install
    Senior Member Three Rings womensecks's Avatar
    Mar 07 2008
    2005.5 avant, 1991 e30
    torrance//socal
    Re: DTM Grill
    fog bracket has been done for the DTM bumper, however, you need to take into consideration the airflow to the sidemounted intercoolers.
    A bracket should be easy to do ... but I think it will block a lot of the flow especially since the very far end grilles are faux grilles.
    i love you
    2005.5 b7 a4 avant 2.0T quattro, sold
    1991 e30 318is coupe
    1988 e30 m3
    -theworks
    Re: DTM Grill
    ^^ AWE FMIC will take care of that problem
    Feb 16 2008
    Oakdale, MN
    Re: DTM Grill
    HAHA yes it would. But are the fogs really that big that they will be a probelm for air flow?
    The usual things!!
    Resistor Install
