Results 1 to 3 of 3
    Senior Member Three Rings tommy782's Avatar
    Aug 01 2008
    canada
    MODIF change sotck air filter by KN
    I bought a KN air filter for my b6 2003. I bought to a small air filter to put on the air pump. what element do I remove for this? air box, the pump and??
    thx!!
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Re: MODIF change sotck air filter by KN
    I know you are from Up North, but your English shouldn't be that bad, take 2 more seconds and get your thoughts down clearly!
    If you are doing the cone filter swap, you are going to remove the air box and most items attached to it (minus some piping and wires). You put the cone filter onto the MAF, and attach via a silicone coupler of sorts with clamps. You put the smaller filter onto the breather hose and attach via a hose clamp.
    Check out
    www.a4mods.com
    Or do a simple search.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
