Results 1 to 6 of 6
Thread: HELP!
    Sep 18 2008
    Red Deer
    HELP!
    Need some major help with a '98 A4 2.8L V6 that has me at the end of my rope. VAG read says cyl 1 misfire. Replaced coil pack, plugs, plug wires and MAF sensor. Even replaced valve cover gaskets because buddy of mine said he worked on one with cyl 3 misfiring and that did the trick somehow. Someone please help, don't know what else I could do.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: HELP!
    swap injectors with another cylinder and see if anything changes.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Registered Member Two Rings
    Jun 02 2008
    Renton, WA.
    Re: HELP!
    How is your valves? There could be a burnt valve causing that. Good luck.
    Sep 18 2008
    Red Deer
    Re: HELP!
    Injectors and valves are fine. When I disconnect the MAF sensor the cylinder stops misfiring. Guess it's to do with the programming but since it's a '98 cannot really alter the fuel going to the cyl can you? Any other suggestions?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Re: HELP!
    ECM
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: HELP!
    since when is this an a4 forum?
