Results 1 to 4 of 4
    Established Member Two Rings 377Z's Avatar
    Aug 25 2008
    Chicago, IL
    Are B6 3.0 Quattro Cabriolet brakes different from a basic 15" wheeled B6 1.8T?
    Does anyone know whether the brakes on a non-sport package 2004 A4 3.0 Quattro Cabriolet are any larger or different at all from a regular B6 1.8T sedan?
    2007 Volvo S60R
    2005 A4 2.0T Quattro
    1998 Ford Explorer Sport 4X4
    Established Member Two Rings samaritano's Avatar
    Jun 05 2007
    Miami, FL
    Re: Are B6 3.0 Quattro Cabriolet brakes different from a basic 15" wheeled B6 1.8T?
    Taken from the "Ultimate modification thread" on the B6 A4 forum.
    OEM Brake Upgrades
    B6A4 1.8t- Same Caliper as B6A4 3.0
    Front Rotor: 288x25
    Rear Rotor: 245x10 or 255x12
    To check size of rear rotor, remove and check part #:
    8E0 615 601 P = 245x10mm
    8E0 615 601 D = 255x12mm
    B6A4 3.0- Same Caliper as B6A4 1.8t
    Front Rotor: 312x25
    Rear Rotor: 255x12
    B5S4
    Front Rotor: 321x30
    Rear Rotor: 256x22
    B6S4- Same Caliper as B7A4 & B7S4
    Front Rotor: 345x30
    Rear Rotor: 300x22
    B7A4- Same Caliper as B6S4 & B7S4
    Front Rotor: 320x30
    Rear Rotor: 288x12
    B7S4- Same Caliper as B6S4 & B7A4
    Front Rotor: 345x30
    Rear Rotor: 300x20 "
    Hope it helps.
    Edgar
    Aug 25 2008
    Chicago, IL
    Thank you so much.
    Weird that the caliper is the same, but the rotor is larger.
    2007 Volvo S60R
    Jun 05 2007
    Miami, FL
    Quote Originally Posted by 377Z View Post
    Thank you so much.
    They just use a larger caliper carrier, that you can buy if you want to go with larger rotors.
    Edgar
