Page 1 of 4 123 ... LastLast
Results 1 to 40 of 124
Thread: BIG TURBO part3
    Senior Member Three Rings a4mafia's Avatar
    Aug 22 2008
    B5 A4 Avant. Ford F250 PSD. Mazda3. Raptor 700r.
    Cincinnati
    BIG TURBO part3
    okay so i came up with a list and the price and the website. should this be good? also there are a couple things i cant find so i need some help.
    A4 Big Turbo Setup
    -GT3076R Turbo: $1250 www.ecodetuning.com
    -SPA Manifold: $495 www.034motorsprt.com
    -Southbend Stage 3 Clutch: $600 www.ecodetuning.com
    Eurodyne Tuning: $750 www.eurodyne.ca
    -630cc Injectors:?
    -Test Pipe: $395 www.atpturbo.com
    -SCAT Rods: $375 www.034motorsport.com
    -Turbo Timer: $100 www.ecodetuning.com
    -Boost Controller: $165 www.ecodetuning.com
    -Intercooler?
    -Forge BOV/DV Splitter: 160 www.ecodetuning.com
    -MAF: $150 www.034motorsport.com
    -Lines?
    -Silicone?
    let me know anything. my mind is open.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: BIG TURBO part3
    i think you should be able to find a test pipe for less than 400 bucks. that's kind of a lot
    {99.5 Avant}
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: BIG TURBO part3
    higher flowing head would definitely be on my list also. it'll help out the top end power made available by this large of a turbo.
    stroker kit (2.0)
    ARP bolts
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Jul 07 2007
    Tempe, AZ
    Re: BIG TURBO part3
    Quote Originally Posted by Jibberific View Post
    my test pipes on my S are less than 30 bucks each. go to an exhaust shop and have them fab up a pipe for you, 02 bung, spacer, weld it on, you're good to go
    Jan 25 2006
    A4 2.0T
    MD
    Re: BIG TURBO part3
    Your list needs a lot of work...................................
    Please read the other thread on this topic. Its still on the front page of this forum and it has a better list.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: BIG TURBO part3
    running a GT30 I would suggest building the head, on a 1.8 your not going to take full advantage of the turbo only revving to 7000 and on stock cams. And IDK what would make you think a stage 3 clutch would be okay, you want atleast the stage 4 if not stage 5. EDIT: Also would suggest replacing all your rod/main bearings and piston rings since you gotta do rods anyway. Theres a recent thread about this look at it.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: BIG TURBO part3
    Quote Originally Posted by njm23 View Post
    x2 and your list is missing a lot of stuff that you are going to need or want to replace while you are in there. seals, rings, bearings, etc.
    Sep 23 2007
    Re: BIG TURBO part3
    http://www.kineticmotorsport.com/pro...5-597-139.html
    heres a south bend stage 5 for $50 more
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: BIG TURBO part3
    His list is partial....
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: BIG TURBO part3
    Call up 034MS, or BobQ and get a total breakdown of what's needed.
    Otherwise PM Issam, Mike, or any of the other members that know more of wtf they're doing.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: BIG TURBO part3
    Quote Originally Posted by jturnbull View Post
    How about stage 5 for $1 less then that and free ground shipping (48 states)?
    But I am not sure where he got the stage 3 price for $600 when it retails for $450 + shipping.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: BIG TURBO part3
    <Shameless Plug>
    FS: ATP 3" Downpipe
    </Shameless Plug>
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: BIG TURBO part3
    If you crack open the bottom end to do any work then put it back together with longevity in mind. The additional reliability gained by performing a basic rebuild will mean a lot when pushing 125 hp out of each cylinder. At the very least you should replace the rod bearing shells, piston rings, gaskets, and seals. Timing belt too.
    Jim
    I Do Werk.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: BIG TURBO part3
    U dont need a turbo timer
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: BIG TURBO part3
    you dont need a tt. However that atp "Testpipe" wont work with a spa manifold. the turbo position is different. Like everyone else said with a gt3076. Your gonna wanna do rods, piston rings, main and rod bearings, and arp main bolts, you will also want a head gasket kit since your gonna need to pull the head for that kind of work. which requires head bolts as well. IF you dont wanna do bottom end work, I would reccomend a 2871r at the very most.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: BIG TURBO part3
    Give yourself ~$1k for just the bottom end build, and $1500 if u dont do the rods ureself
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    Re: BIG TURBO part3
    you cna run a stg 3...but its better to go bigger and beefier....
    or youll end up like me afraid to launch your car
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: BIG TURBO part3
    Quote Originally Posted by 1fstavant View Post
    X2,... Until I manned up and now I'm decent at it.
    Mar 09 2004
    nw michigan.
    Re: BIG TURBO part3
    Sounds about right. Especially if you need to buy some tools for the project.
    It can be done cheaper though. Mine was around 700 and that included all of the PCV valves and parts (~2 bills) and a new oil pump. TQMB5's was probably cheaper than mine including that janky engine stand.
    The only problem with these rod swapped homebrews is that the balance might not be as perfect. Since we build these things for 3076 sized turbos and playtime lasts past 8,000 rpm that could present a longevity problem. Mine was done 2 year and 30k miles ago and is smooth like butta. I cleaned the rods up and tossed them and the pistons on the digital scale at the bike shop.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Re: BIG TURBO part3
    I've had the Southbend OFE with SS pressure plate for over 4 years and about 60k miles. I'd go one step up for a 3076. Although it could probably handle race gas pulls I know mine would be happier with less than 450 torques ripping at it. When I bought it the rating was 420 Awtq or 450 Fwtq.
    Jim
    I Do Werk.
    Feb 26 2006
    Earth
    Re: BIG TURBO part3
    Quote Originally Posted by t1demont1 View Post
    Brenden I allready have the downpipes working out for him if he wants the SPA manifold:
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: BIG TURBO part3
    Yeah ive been seeing that everywhere Issam, that downpipe looks too nice.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: BIG TURBO part3
    Quote Originally Posted by onemoremile View Post
    Agreed that balance is an issue on homebrewed setups, but rods are SO good these days that its not the biggest issue imo... All of my rods were within .6 of a gram, I went further and went to .1 of a gram, but Im sure .6 would have been fine... The biggest issue is when people throw bearings in there without mic'ing the clearances, and then people wonder why they spin bearings lol... What did you balance your motor to? I did less than a gram for the crank/flywheel/pulley, and .1 gram for pistons/rods
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: BIG TURBO part3
    Quote Originally Posted by JumboBlack1.8 View Post
    and while your at it. forget the front mount too....hey, and what the hell do you want rods for? that will like make your engine not blow and stuff right....
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Oct 28 2006
    Re: BIG TURBO part3
    Quote Originally Posted by a4mafia(Red) View Post
    you really dont need a turbo timer
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: BIG TURBO part3
    Quote Originally Posted by Issam@034 View Post
    Do you have any in the bay pics yet? Curious how that will clear.
    Sep 16 2006
    '98 528i
    Re: BIG TURBO part3
    U tryin to mock me?......lots of people dont use these....they're pointles...but go ahead and waste ur money if u'd like
    Sep 16 2006
    '98 528i
    Re: BIG TURBO part3
    Quote Originally Posted by bassed View Post
    x2.....really interested in gettin one of these down the road......whats the general pricing on these? I never saw it listed anywhere
    Aug 22 2008
    Cincinnati
    Re: BIG TURBO part3
    haha I love u justin lol not in a gay way though...
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: BIG TURBO part3
    here is a list I put together a couple of months ago with the help of some guys on here... you may need to tweak it a bit for the direction you're going.
    Part:.........................Cost:
    • gt3071......................1100
    • spa manifold................460
    • wastegate setup..........230
    • 630cc injectors...........260
    • ctapp tune (pump).......700
    • lightning maf...............120
    • 3" catback ...............750
    • hfc...........................250
    • fmic .........................900
    • scat rods....................400
    • rod bearings.................80
    • main bearings...............60
    • piston rings ................150
    • main bolts...................20
    • sb stg 4.....................600
    • walbro 255..................100
    • a/f+oil gauge................430
    • ebc...........................400
    • misc...........................1500
    • Total:.......................8510
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: BIG TURBO part3
    depending on how you are planning on driving the car. i would really consider tweaking your clutch setup past the generic stg 3/4/5 options.
    talk to Mike Hood about this. he knows what im talking about and will get you a good price
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    Re: BIG TURBO part3
    We've got lots of IE 144 x 20's in stock, I can do them for $350 with free shipping. We've also got 630's in stock for $47 each. I'll also price match on the exhaust manifold which I have in stock as well.
    Hit me up I'll throw you together a little combo pack. [email protected]
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Aug 22 2008
    Cincinnati
    Re: BIG TURBO part3
    Quote Originally Posted by Kyle H View Post
    i can find most of that stuff way cheaper
    Feb 26 2006
    Earth
    Re: BIG TURBO part3
    Clears just fine.We have a half cut here that we use for mocking up all our parts.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: BIG TURBO part3
    Issam is a great guy to deal with, he can answer all your questions no matter how stupid they seem. and can guide you for a build you will never regret.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Aug 22 2008
    Cincinnati
    Re: BIG TURBO part3
    Quote Originally Posted by pipe7284 View Post
    ^x2!
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: BIG TURBO part3
    Quote Originally Posted by a4mafia View Post
    I know, I just posted it so you have a guideline of parts to get for the most part.
    The prices are a high estimate to compensate for tax and shipping. Good luck
    because racecar.
    Aug 22 2008
    Cincinnati
    Re: BIG TURBO part3
    I appreciate the help bec I need it. Does anyone know if a state 2 ignition required?
    Oct 06 2004
    Minnesota
    Re: BIG TURBO part3
    no
    oh and wtf is that software you want to run?!
    Maybe Search more to find answers?
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: BIG TURBO part3
    Quote Originally Posted by AudiRacerS4 View Post
    so when your driving around. maybe you'll get on it a couple times and then you arrive at your destination and shut off the car?....letting your oil bake and in your 800+ Degree turbo(turbos can idle at 20000 rpm)?!?!?!?!? is this what your trying to tell me?
    lots of people blow their stock turbos bc they dont wait 45 seconds at the end of driving(as recommended by audi) when they're reallll hot and the oil sludges up and eventually blocks up the flow....
