Results 1 to 31 of 31
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Parting Out: 1999 A4 1.8T 5spd Quattro Volcano Black/Black Sport Pkg. 138k Miles
    We have just received in a new parts car! It is an early 1999 A4 1.8T Quattro with a 5 speed manual transmission. The car has just under 138,000 miles on it, and was involved in a front-end collision. We were able to start, run, and drive the car around--the engine runs great, brakes work well, suspension is intact, and the transmission shifts nicely. However, after inspecting the car, the following items were found to be damaged, faulty, or untestable--
    -ABS Module
    -Hood
    -Left Front Fender
    -Front Bumper
    -Intercooler
    -Airbag Module
    -Power Steering Pump
    -ECU (Already in use)
    Note that we have most of these parts available in our regular inventory, so if you're looking for one, browse our eBay store or shoot us a PM or email at [email protected].
    On to the price list! Note, we have almost 900 A4 parts listed online here, this is just a small summary of the parts we can and will sell! If you see it, we sell it!
    Contact us via PM here or email at [email protected] with your requests! Email is the most efficient way to get a hold of us!
    Buyer pays shipping on everything, we will ship to Canada. Domestic shipping is UPS Ground and varies from $10-15 for most items to anywhere in the lower 48 states. Contact us for a quote if you live elsewhere.
    Note, the list below is a general overview of pricing for common items that we currently have in stock.
    Engine
    Complete 1.8T Engine w/Wiring Harness (Code "AEB") - $1500 (137,XXX Miles)
    Transmission - $500
    Turbo K03 - (Minimal Shaft Play - GOOD!) - $150
    Timing Belt Covers - $25/ea
    Belly Pan - $50
    Throttle Body - $125
    Intake Manifold - $50
    Exhaust Manifolds - $50/ea
    MAF w/Sensor - $80
    Power Output Stage (POS) - $60
    Coil Packs - $15/ea
    Fuel Rail - $40
    Fuel Injectors - $15/ea
    Engine Mounts - $40/Ea
    A/C Compressors - $50
    A/C Condenser - $50
    Radiator - $50
    Radiator Core Support w/o Fans - $150
    Radiator Cooling Fan (Electric) - $60
    Viscous Fan Clutch (w/o Fan) - $40
    Viscous Fan Wheel - $20
    Starter - $50
    Alternator - $50
    Oil Cooler - $30
    Power Steering Cooler - $30
    Power Steering Pump - $50
    Differential - $50
    O2 Sensors - $40/Ea
    Coolant Reservoir w/sender - $30
    Wiper Motor - $30
    Wiper Linkage - $50
    Washer Spray Nozzles (Headlight) - $40/Ea
    Washer Fluid Reservoir - $40
    Washer Fluid Pump (Main) - $40
    Washer Fluid Pump (Head Light) - $40
    Shift Linkage (5sp) - $40
    Air Filter Box - $40
    Air Filter Box Ducts - $20/Ea
    Fuel Pump - $80
    Fuel Sending Unit - $30
    Drive Shaft w/Carrier Bearing - $100
    Clutch w/Flywheel - $150
    Brakes/Suspension
    ABS Speed Sensors $40/Ea
    Brake Calipers w/Carriers - $50/EA
    Brake Booster - $40
    Brake Master Cylinder - $40
    Brake Fluid Reservoir - $25
    Front Rotors - $15/Ea
    Rear Rotors - $15/Ea
    Tie Rod Assy- $40/Ea
    Control Arms $40/Ea
    Differential - $50
    Axles Rear - $50/Ea
    Axles Front - $50/Ea
    Rear Knuckles/Knee Assy w/Hubs - $50/Ea
    Exterior/Body/Lighting
    Corner Markers - $30/Ea
    Driver's side Mirror Housing (No Glass) - $50
    Passenger's side Mirror Housing (No Glass) - $50
    Trunk - $150
    Grill (Badged) - $50
    Bumper Grille Lower (L/R) - $25/Ea
    Bumper Grille (Center) - $30
    Window Frame Assy With Windows (no Motor) - $75/Ea
    Side Windows (Glass Only) - $50/Ea
    Window Frame Assy W/O Windows (no Motor) - $25/Ea
    Front Fenders - $100/Ea
    Door DS Front - $100
    Door DS Rear - $100
    Door PS Front - $100
    Door PS Rear - $100
    Exterior Door Handles - $40/Ea
    Fender Liners - $30/Ea
    Moon Roof Assy Complete (Glass) - $150
    Rear Bumper Assy - $150
    Rear Bumper Shocks - $40/Ea
    Front Bumper Assy - $200
    Front Bumper Shocks - $25/Ea
    Door Weather Stripping all four doors - $20/Ea
    Rear Tail Light (Lens only) - $60/Ea
    Tail Light Bulb Holders - $30/Ea
    Interior/Electrical/Stereo
    3 Spoke β€œSport” Steering Wheel - $175
    Instrument Cluster w/o info display - $60
    Beltline, w/o Radio and shifter Surround - $125
    Radio Surround (Black) - $40
    Shifter Surround (Black) - $30
    Climate Control - $100
    Central Locking Pump - $100
    Cruise Control Module - $60
    Airbag Module - $80
    ABS Computer - $100
    Shifter Knob Black Leather - "Sport" - $50
    Shifter Boot Black Leather - $25
    Radio - Non-Bose Delta with Code - $75
    Non-Bose Speakers - $40/ea
    Pillar Trims A,B,C - $30/ea
    Headliner with Sunroof cut-out - $100
    Dash (Black) - $150
    Passenger Air Bag - $100
    Sunroof Switch Panel w/Lights (Good Condition) - $60
    Front Driver's Seat (Leatherette) - $150
    Front Passenger Seat (Leatherette) - $100
    Rear Seat - $100
    Black Leatherette (w/ Good Armrest cover) "Sold As Set ONLY"- $100
    E-Brake Handle - $30
    Door Pulls Black (no switches) Good Condition! - $40/Ea
    Sun Visors - $20/Ea
    Column Switches/Stalks $30/ea
    Window Switches - $10/Ea
    Seat Heater Switches - $15/Ea
    Interior Door Handles Black/Silver Good Condition - $30/Ea
    Sunroof Motor - $75
    Window Motors - $40/Ea
    Window Regulators - $40/Ea
    Kick Panels - $20/Ea
    Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $100
    Blower Motor Fan Assy - $60
    Rear Window Deck w/3rd Brake Light - $50
    Tilt Steering Assy. w/ignition and Key - $60
    Center Heater Vents (3 total, sold separately) - $15/Ea
    Side Vents - $15/Ea
    Rear Vents - $15/Ea
    Overhead Grab Handles - $10
    Front Seat Belts - $50/Ea
    Rear Seat Belts - $25/Ea
    Interior Floor/Door Trim (from Front to Back) - $50
    Exterior Black Door Sills - $50/Ea
    Center Rear View Mirror (Windshield) - $40
    Again, for any questions or to order, shoot us a PM through AZ or an email at [email protected].
    We have our ENTIRE parts inventory posted on our eBay Store--over 900 individual items from 96-01 A4s, 92-97 100s/A6s, V8 Quattros, etc.--all posted with pictures. Browse our inventory at your convenience!
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Jun 20 2007
    2012 JSW TDI
    Raleigh, NC
    Re: Parting Out: 1999 A4 1.8T 5spd Quattro Volcano Black/Black Sport Pkg. 138k Miles
    so the seats are black? (i need a gray one)
    also, may be interested in the cruise module (or the stalk), gotta check to see what is wrong with mine
    what about the lower trim piece on the rear passenger door (outside)?
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    i need the driver side windshield side molding...only the driver side...how much shipped?
    Oct 29 2005
    10speed
    San Francisco, CA
    $1500 for a motor with 138k? sheesh
    - Clint
    Veteran Member Three Rings jankaroni's Avatar
    Mar 01 2007
    Emerson/NJ/USA
    i need the trim piece that goes around the flasher and the cup holder in the center console portion....how much for it?
    Mar 15 2008
    A few Audis
    Independence, MN
    All who have responded have been PM'd!
    Sam
    Mar 15 2008
    A few Audis
    Independence, MN
    All of the above requests have been responded to via PM, thanks guys, keep 'em coming!
    Sam
    Registered Member Two Rings Audiman23's Avatar
    Aug 09 2007
    Audi A4
    Napa, Ca
    i have a 97 audi a4 1.8t quattro.I might need a new flywheel and might as well put in new clutch right?right now have stock from 97 thks
    Mar 15 2008
    A few Audis
    Independence, MN
    Check your PMs Audiman. Bump!
    Registered Member One Ring Narcissus's Avatar
    Feb 07 2005
    1998 Audi A4 Quattro 1.8T
    Dallas, TX
    How is the headliner? Need to replace mine on the '98.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Narcissus View Post
    You should suede it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Would you part a window regulator wheel?
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings savetheclutch's Avatar
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    how much for all the seatbelts (if black) and the rear deck mailed to 07024?
    AKA: andresito360
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    I'll take the drivers seat if its black & leather along with the drivers side mirror
    Oct 10 2006
    would the Central Locking Pump work on a 2001?
    Oct 06 2004
    Minnesota
    Bump for AWESOME seller!
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    how much for a rear spring?
    Jun 23 2008
    CA
    how much are both front axles shipped to 93065?
    thanks
    Senior Member Two Rings cmorse's Avatar
    Oct 23 2006
    virginia tech
    you got a pm for interior pieces.
    Oct 10 2006
    part number for central locking pump?
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Will driver and passenger front airbags work in a 2001 a4? And the dash? And the front windshield? :)
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Established Member Two Rings A3toB5's Avatar
    Sep 22 2008
    99 A4 1.8t & 95 Golf 2.0
    Queens Get The Money
    do u have the under the engine bay protector.. ? if so how much ?
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump! I've responded to all requests, PMs, and thread replies over the past few days--I apologize for the delays on some of those, we're trying to work some new staff into our forum activities and it's been a transition. Thanks all for your patience, I hope we've been able to help some members out.
    Sam
    Sep 17 2006
    07 cbr600
    didnt reply to my email i sent weeks ago about the sport emblem on the steering wheel
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by Russell2686 View Post
    My apologies, just sent you a PM.
    Bump!
    Sam
    Mar 29 2007
    Is the street.
    Quote Originally Posted by Bic-Ball View Post
    Mar 15 2008
    A few Audis
    Independence, MN
    Replied this morning, my apologies for missing you!
    Sam
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    do you still have the rear tie rod assmebly, and is it in good condition?
    Oct 03 2008
    Grand Terrace, CA
    do you have the headlights? how much shipped to 92313?
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    dibs on the aluminum interior belt trim please.
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    I am looking for a headlight/combination switch for my '98.
    Please let me know if it is available.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
