Results 1 to 11 of 11
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    launch=flashing brake light?
    So ever since i bought the car i have had this problem where the brake light in the dash will blink and ding at me me when i launch the car/or shift rather spirited WTF is that? Am i overboosting on stock tune? Or a bad/corroded sensor that comes loose then goes back in place? I have no other lights on besided that one once in a while... And yes i tried a search but nobody had the problem when launching only when normal driving so im sure if i am on the same page as them... Any ideas?
    Jan 25 2006
    A4 2.0T
    MD
    Re: launch=flashing brake light?
    Possibly the ABS unit using its Electronic locking..... I wouldn't know since my ABS has never worked
    Apr 01 2007
    Irvine
    Sounds like the ASR kicking in. It's tied to the ABS sytem. does your dash have a button that says "ASR" on it? If so, turning it off should fix the "problem".
    Aug 16 2007
    Buffalo NY
    i dont think so.. Its a 1999.5 a4 1.8tqm
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by slopoke View Post
    which means you dont have ESP so it may be a problem with you ABS unit
    Aug 16 2007
    Buffalo NY
    gay... Well i doesnt effect the vehicle what so ever and doesnt occur when braking some the hell with it
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Did you check to make sure you have enough brake fluid? If so it is most likely a bad ABS sensor or the module itself.
    Mar 18 2007
    Boston, MA
    Even when my brake fluid level looked only slightly below the "full" mark, when I hit a big bump or a corner it would do it once in a while. I just topped it to the actual full mark and have never seen it since!
    03 Evolution 8
    98.5 A4 1.8T
    99 A6 2.8
    Aug 16 2007
    Buffalo NY
    hmmm may have to go check thanks guys
    Dec 05 2007
    CA LA
    uummmm mine does the same thing when i do a light spin of the tires on a launch or a hard 1-2 shift. as far as i know its a normal thing. vw has a weired traction control that uses the brakes even if you dont have an ESP or ASR button
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Quote Originally Posted by legionvr6 View Post
    light spin not for me Quattro
    but my wifes Jetta can spin all day long and the ESP goes crazy especially with the crappy stock tires I got her some Continental's extreme contact i think they are and got a lot better
    way Off topic sorry i'm bored at work!
