Results 1 to 23 of 23
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Question Will This Fit Without Rubbing? (Flushness and Camber Experts Only!)
    Right now I have 19x8.5 et35 rims with 235/35/19 tires on every corner. along with this each corner has a 5mm spacer, bringing the offset to et30 all around.
    I rubbed pretty bad in the rear and decided to cut the fender liner:
    Doing this made rubbing disappear about 90%
    I have been running this setup for about 6 months and its great and only rubs slightly with 4ppl in the car on the freeway or on dips
    But.....
    19x8.5 et30 in the rear isnt flush enough for me so i put on my 15mm spacer on the rear and got this:
    this makes me happy because its flush and looks great as a stance
    the stats are 19x8.5 et20 with 235/35/19 and it looks sick
    Now even with the fender liner cut it rubs mad! like just under normal driving and normal smaller bumps int he road would cause it to rub excessively.
    I was planning on getting an alignment tomorrow and getting an:
    "aggressive street setup" : with around 1.5 to 2.0 negative camber in the rear. (anyone who has a good suggestions based on pics gimme a idea)
    Looking at that picture and estimating the camber do you think this will fit with minimal rubbing?
    I dont have the exact measurements of my drop but heres a really old side shot to give an idea. i know its pretty dropped right now at a great height and i dont want to change that by raising it.
    I think I am afraid of having the aggressive street setup on my alignment and having the 15mm spacers in the rear still rub to the point where i dont want to drive with them on and having to switch back to the 5mm spacers and have the stance looking weird with the slightly tucked rims and cambered wheels.
    Sorry for the long post... anyone have thoughts?
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: Will This Fit Without Rubbing? (Flushness and Camber Experts Only!)
    do the bumper markers in the front and rear interchange, like if i wanted red in the front, i would just get a spare set from a rear? you had me thinking, looked sik by the way with rhe 15mm , u said u cut ur liner, why didnt u just roll ur fenders?
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    I haven't tried anything aggressive on the A4 yet but previous experience is to camber as much as possible if you don't want to run smaller spacers. If a credit car or a couple sheets of paper can pass through it, it won't rub on the quarter panel. Have a friend or two sit in the trunk and some more in the back seat to get it to compress. That's what we usually do to get it to barely clear which would help keep the look you want. Judging from the pictures, I say a simple camber adjustment would make it work. Or run a more rounded tire.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I have an ET32 on a 19x8.5 and I sit flush.
    Are you sure your rim width and offset are correct?
    Jan 14 2008
    San Antonio, TX
    ^ Yeah I am pretty sure. hard to mistake your offsets.
    Either way with the 15mm spacer there i have it at a stance i love.
    May 03 2008
    Monterey, CA, 93940
    ^ your not slammed as low as him tho clearly with the 19s....won't fender rollin solve this problem?
    Sep 14 2006
    Australia
    i have my car at -2
    Audi A4 B7 Sline 2TQ
    APR programs,APR K04, APR exhaust, APR fuel pump, Carbonio CAI, KW V3's, RS4 Grill,RS4 rear swaybar, 20'' Verde kaos,Defi boost gauge, Racetec FMIC
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by 06B7audiA4 View Post
    That wasnt my point.
    My point was at a ET32 I sit flush and he doesnt on the same width wheel.
    May 03 2008
    Monterey, CA, 93940
    ^ I just know that before i did my suspension and went lower, i thought I was gunna need a bigger spacer, turned out i only needed 5mm in the back and none in the front to be pretty flush...so i figured since he was lower, it was a difference becuase ur height is higher..haha i wasnt trying to argue :P
    May 03 2008
    Monterey, CA, 93940
    ^ i like those champions by the way, haha
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    fender rolling will cure your problems dude
    setting at -2 you'll still rub with +20 in the rear
    Im sitting at 19x9.5 + 35 and Im rubbing without any passenger in the rear
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    I'm at 19x8.5 with ET 35 with no rubbing whatsoever but i'm gonna throw 5mm in the fronts and 10mm in the rear to get that agressive stance going, will keep you posted
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    I've rollled fenders before on a mustang and a skyline....but i don't see how rolling fenders on a B7 (or even a B6) can help that much....its already 'rolled' from the factory.
    Is it possible to make the inner fender-lip any flatter than it already is?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    You should not in any way whatsoever be able to have a +20 wheel "FLUSH" with the fender. I have 19x8.5 +35 245/35/19 and I dont even think I could fit a spacer on it, although I considered it, it doesn't look like it would come close to fitting...
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Here is the bigger issue. You want it flush - but you rub. If you add around -2 camber it may not rub anymore but now it will not look flush because the tops of the tires will "lean in" toward the car - that is why the rubbing stops. If you must have it look like does now (I.E. - looks good but rubs), your only option may be to raise the car slightly.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    May 03 2008
    Monterey, CA, 93940
    ^ might be rolled from the factory, but they dont surely expect you to be slammed cruisin on 19's....Im bout to get my fenders rolled just so I dont rub at all, I barely do now, but its a safe option when you dont want to rub those tires away...I actually got an allignment and it fixed alot, but also took them over 4 hrs to do :P it was that off...but not noticable from my stand point till i saw my tires..ROLL THOSE FENDERS and i will make a safe bet, ull be happy..
    Jan 14 2008
    San Antonio, TX
    Exclamation Re: Will This Fit Without Rubbing? (Flushness and Camber Experts Only!)
    Quote Originally Posted by SGVA4 View Post
    Are your liners cut?
    Apr 15 2007
    WNC
    Quote Originally Posted by MOFSTEEL View Post
    Hotness. I dream of owning an Audi with those wheels.
    2013 RS5, 2014 Q7
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Quote Originally Posted by B7! View Post
    i have my car at -2
    Well isn't that special?
    (-4.5 degrees, 18x10 et27)
    For the OP, you might want to try this:
    http://www.audizine.com/forum/showthread.php?t=210830
    -Darrick
    Sep 14 2006
    Australia
    Quote Originally Posted by Capt. Obvious View Post
    yeah but thats cheating tho!!
    Jan 14 2008
    San Antonio, TX
    it fits and barely rubs. running -2.4 L and -2.7 R camber in the rear with minimal rubbing
    Mar 03 2008
    626 SoCal
    Quote Originally Posted by Elohite View Post
    NO...and Im not gonna go that route
    Im bout to get coilovers so I can adjust my rear height though Im currently running Eibach/Bilstein set up. Rides nice but ever since I sold my LM TA and rolling on Works I've been rubbing like a madman
    "J Spec B7"
    Veteran Member Four Rings Dangler's Avatar
    Quote Originally Posted by mattman View Post
    x2
    there is nothing to roll in the rear...you need to have the fenders PULLED....not ROLLED. you can roll the fronts, because there is material to roll.
    i have 19x9 et 41 all the way around 225/35/r19 tires. i had 20mm spacers in the rear bring the offset to et21. I only rubbed after i installed the stereo system. so i took them out
    PRIME MOTORING
    F.T.W.L.T.B.D.W.I.C.T.W
