Results 1 to 8 of 8
    Active Member Three Rings turboquattro068's Avatar
    Mar 20 2005
    99.5 Audi A4, 99 Honda CBRf4
    Upstate, new york
    Do I need this for my suspension
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: Do I need this for my suspension
    Nope.
    IIRC all the tools you need to take apart the front suspension are 16/18/19 mm wrenches/sockets. a BFH and screwdriver help with the pinch bolt, too.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Mar 20 2005
    Upstate, new york
    cool, what about the rears?
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Ohh shit I can't remember exactly... same stuff and I think you need a 13mm socket for the strut mount, and you'll want some good sized extensions and a swivel to get to those.
    This is a pretty good writeup to read through before you begin:
    http://www.audiworld.com/tech/wheel28.shtml
    because racecar.
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    dont forget the elbow grease and alittle bit of muscle ..or air tools, same thing.
    "slow is smooth and smooth is fast"
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    You don't need to go near the pinch bolt. There are a pair of small removable plugs by the false firewall that hide the strut bearing mounting nuts. Remove those and the lower strut mount bolt and pull the assembly out.
    Dan (DJWimbo) and I did this on the S4 a week or two ago. That one had the front lower mount bolts in backwards which made it much more difficult that it needed to be.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by onemoremile View Post
    Word. Don't put the bolts in backwards at the bottom of the strut. It makes removal a PITA.
    the tool you speak of is handy for some other VAG cars, but I've yet to use it on a B5. Mk4 I use it a lot for spindle removal.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Everyone says how bad the pinch bolts are, but mine came right off first try!
