Results 1 to 3 of 3
    Sep 15 2008
    San Diego
    Sportec Mono 10's
    Does anyone know if this particular rim that are 19x9.5 with +35 offset will rub on a 2004 A4 3.0? Looking to buy a set from someone here and not sure the fenders need to be rolled once the car is lowered for the fronts.
    Any info will help. Thanks.
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: Sportec Mono 10's
    I think this question has been asked and answered about 3-4 months ago. Do a search on the main B6 Forum and you'll find your answer.
    Registered Member Four Rings
    May 11 2007
    RS6 Avant/996 GT2/'08 335i
    Southern California
    19x9.5 will NOT fit on the front. It should fit in the rear if you run some negative camber with the right tire size, but you'll need a 19x8.5 in the front.
