Results 1 to 8 of 8
    Sep 15 2008
    97 A4 1.8T Quattro
    huntersville, NC
    thermostat problems...please help!
    it seems the my thermostat is always cold...i dosent seem to move at all...so i need to replace it right...how much is it to buy one...and how hard would it be for myself to do it...with somewhat mechanical knowledge??
    thanks!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: thermostat problems...please help!
    Does your engine temp gauge stay at cold? Thermostat is not the easiest thing to replace on the 97 but doable. It could also be a coolant temp sensor that's faulty. Check out www.mjmautohaus.com
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Start it, drive it about 10 minutes and see if the radiator hoses are warm bordering on hot.
    If they are, the coolant temp gauge should have moved some..
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    I've got a similar problem, I know it's the thermostat because it's already been diagnosed by the dealership. It gets stuck and usually reads lower than it should but mine doesn't stay always at 60, it will go to 70 or 80 but if it ever does go to 90 it won't stay there.
    Are they any easier to change on a 2001? I'd rather not pay the dealer over $300 if I don't have to...
    x2 on "how much is it to buy one"? And from where to get the best price?
    Apr 01 2007
    Irvine
    I had this problem too - it would go up to midway during city driving, but on the freeway it would drop back to halfway between cold and middle. It all went away after I did my timing belt/water pump.
    If you're going to swap out the pump, might as well do your timing belt at the same time and save some trouble. ECStuning usually has complete kits (belt, tensioner, water pump, coolant) for around $290:
    http://www.ecstuning.com/stage/edpd/...ategory=Timing
    For the price of just the thermostat, you can get every single thing done. It's a pain the first time if you've never taken the front end of the car off, but once you're fluent you can do a timing belt job in just under 2 hours start to finish. Give yourself 8 hours the first time to do everything right. I'd probably be able to do it under 2 hours if i didn't have to wrestle with my FMIC every time i put the bumper back on.
    Jul 20 2007
    1998 Audi A4 1.8T
    Concordia University St. Paul
    Quote Originally Posted by price View Post
    thanks!
    This past spring I changed out the thermostate and water pump...its pretty easy but the only hard part is that you put it in upside down so it wants to fall out before you can put the cover on so what I did is put some(a little) grease on it so that it would stay in there enough time so that i could screw the cover on...Thats how it was on my 1.8 i'm not sure if you have the 1.8 or not but thats how you do it...there should be some DIY write up about this..but its pretty easy
    Performance ECU chip, K & N air filter, After market clear headlights and turn signals, Dual chrome exhaust tips, window tint, boost gauge,S4 steering wheel, De-badged grill, De-badged, Red painted brake calipers, Test Pipe, 2 12" Punch P2 subs, 1000 Watt Kenwood Amp, Capacitor, 4 Gauge Monster Cable, Driver Mod
    Jan 17 2007
    Quote Originally Posted by crono35 View Post
    There are three different thermostats listed on that page you provided the link for; two of them state that they run colder which would use more gas (which is the problem I have now) but does the third one match OEM exactly?
    Also, why are the two colder ones more expensive than the third one?
    Sadly my timing belt has already been done so is it really the same amount of work for the thermostat? It can't be or the dealership would charge more I would think...
    Apr 01 2007
    Irvine
    hm, I got the one that came in the kit and everythign seems to be working properly. I'm sure if you contact them they'll tell you which one matches OEM exactly.
    Actually come to think of it, I was thinking that replacing the water pump takes about the same amount of work as replacing the timing belt. Thermostat is much easier, just drain the coolant and you can get to it from under the car.
    I tried looking for a writeup, but didn't find one for the B5.
